| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello all
I have a Philips CD304mk2, and opened it because the servo wasn't working anymore. Fixed the servo allready, a bad connection. But when i checked the chipset, discovered a 40 pin SAA7210-like chip but with another stamping on it: "M4804A" I was suprised of this because the other chips was of the standard 16 bit stuff: SAA7220, TDA1541(plain), a RAM, and a 74/74 for dig out. Btw, most of all are produced year '86. So: is the M4804A a pre-7210 or is it another decoder-chip?
Daisy Bell |
#2 |
I've got one of them Mxxx chips in my Mission PCM7000. It had a tda1541 from 1986! http://www.diyaudio.com/forums/showt...051#post206051 Cheers, Ashley. |
#3 |
I have problem with cd 304mkII. It has disc start-up problems.
When I press start the CD begins to turn around, but the arm of the laser does not move. It could be a problem of Servo (M4814A)? Is it possible replace it with cs8412cp? Many thanks Andrea |
#4 | ||
Thanks Ashley, its obvious now: my search here was not thourough enough.
So the M4804 is a pre 7210, with its problems: In post 5 is a comment of starting problems with 4804: My 304 is indeed not a quick starter compared to my newer ('87?) CD640 and 660. Quote:
If the connection is allright, there is more wrong. Then you need a service manual and search it all out.
Daisy Bell |
#5 |
Thanks Tubee,
I have check allthings but I don't solv the problem.... Do you know where I can founf the service manual?? Bye Andrea |
#6 |
http://user.planetaclix.pt/
If you can read dutch! But schematics are internationally readable i guess. Choose CD304 as mkII not available, but the 304 has same CDM and servo pcb as MKII's, even partnumbers are the same.
Daisy Bell |
| Philips CD304Mk2 dig. out sibilance | PetrL | Digital Source | 4 | 1st April 2008 12:20 AM |
| Page generated in 0.08088 seconds (74.61% PHP - 25.39% MySQL) with 10 queries |
