ASRC - I'm confused on clock choice and word length
I would like to connect a PCM2706 to an AD1895 sample rate converter, configured for 96kHz output data.
I assume the input is run in slave mode, and the output in master. Would I therefore use a 96kHz * 256 =24.675MHz crystal?
Also, the PCM2706 is specified as 16bit I2S output. The AD1895 indicates I2S compatible on the input, but does not list a specific word length. Will this work without glue logic?
Thanks for your help.
