| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
What is the best way of connecting digital outputs up to 5 cm between board and bnc plug to avoid reflections?
#2 |
If it's 75 ohm, I would suggest using 75 ohm coaxial cable - particularly as the BNC is designed for it.
Nigel Goodwin |
#3 |
Reflections come from impedance missmatches. Use the right impedance cable and connectors.
#4 |
in extremely-vital-impedance situations, I just strip and solder coax directly to the PCB.
#5 |
Banned
Belden makes a cheap coax that works ok, and is very flexible...........9210, I think.
RG-179......-184 (I think those are the right ones) work, but can be harder to work with. Jocko |
#6 |
Standard UK TV aerial downlead would be fine - not the cheap and nasty patchcord stuff though.
| Short connections (<1m): Buffered i2s or SPDIF? | NeoY2k | Digital Source | 14 | 6th June 2008 12:02 AM |
| Twisted? | FastEddy | Solid State | 13 | 8th August 2006 03:38 PM |
| Parallel amps & Parallel Voice coils? | officeboy | Multi-Way | 7 | 26th May 2004 07:12 PM |
| Twisted Pair | fmak | Digital Source | 51 | 22nd May 2003 07:42 PM |
| Page generated in 0.07888 seconds (77.97% PHP - 22.03% MySQL) with 10 queries |
