Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd June 2003, 05:37 PM   #191
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Too bad that that part is not available from Farnell
I thought he recommended Motorola parts, probably some damaged brain cells again here
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits...
Old 2nd June 2003, 06:02 PM   #192
Raj1 is offline Raj1  United Kingdom
Default lm317
How about the lm317T's, how do these compare to the 78** series etc?
Raja
Old 2nd June 2003, 06:54 PM   #193
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Njm7805
Fedde
Hi Fedde,
No brain damage over here!
Found back the post. It is # 12 in this thread!(end of point 7)
http://www.diyaudio.com/forums/showt...7078#post77078
Good luck,
Old 2nd June 2003, 07:48 PM   #194
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Re: lm317
Raja
that's a good question!
Old 2nd June 2003, 08:45 PM   #195
[QUOTE]Originally posted by fedde
[B]Too bad that that part is not available from Farnell
You can get the NJMs from rswww.com
Old 3rd June 2003, 12:37 AM   #196
I could not find the NJM parts at rswww.com
Anyway, it would be to costly to get them to the Netherlands. Probably I would end up paying >50$ for a couple of regs.
Fedde
Old 3rd June 2003, 08:01 AM   #197
Fedde
It's in their paper catalogue. Tell me what you need and I shall see if I can get them for you.
Old 3rd June 2003, 11:12 AM   #198
That's cool! I sent you a private mail regarding this...
Fedde
Old 2nd November 2003, 12:53 PM   #199
Happy Ears's Avatar
Default Re: Re: Elso
Originally posted by Elso Kwak
Hi Andy,
I am not sure but I suspect the TDA1543 is spitting HF-garbage back into the powersupply. And second with all these clocks running in the same enclosure, Latch, Bitclock, etc. these might couple into the powersuply too, upsetting the regulator.
Elso , I was reading this former post cq disscussion about your 1543 power supply circuit ... interesting debate !
If there is any suspect that the 1543 dac is reversing HF garbage
back into the circuit ... why not using a coil to avoid this ?
perhaps interesting for Fabian too !
When to use 317 and 7805? Sunsun22 Power Supplies 8 6th April 2009 07:47 PM
PSU with Multiple 7805 // Ciu Power Supplies 5 24th March 2007 04:46 PM
7805 trouble DragonMaster Power Supplies 4 23rd October 2005 03:38 PM
Very low noise 7805? ChuckT Digital Source 34 15th October 2005 03:47 PM
LM1085: low noise vs stability? patwen Digital Source 8 29th October 2002 11:12 PM
Page generated in 0.11878 seconds (78.74% PHP - 21.26% MySQL) with 11 queries
