| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
diyAudio Moderator Emeritus
2200 uF is too large behind the regulator. What is the purpose of such values ?
I once modified a Sony SACD player by changing the too big caps with smaller ones ( 100 uF ) and it sounded better. I also remind a Marantz CD 60 SE that had too large caps behind the regulators. The result was when switched on it took almost 15 minutes before the supply was stable. It was "motorboating" ( Low frequency oscillation ). Changed the caps to 100 uF and the problem was solved.
It's only audio |
#12 |
diyAudio Retiree
This is an interesting topic and 60 pages of post could still not exploit all the factors involved in power supply design for audio and digital circuits. I will throw out a few observations and stand back and wait for the backlash.
1. Power supplies have an enormous influence on the sound of circuit and factors all the way to the AC outlet have an influence. 2. PSRR of the regulator (particularly at RF frequencies) has even more of an impact than output impedance on many regulators circuits. 3. Transient response of a reglulator has as much to do with sonics as absolute value of the output impedance. This may explain the preference of simple followers over feedback circuits by many designers. Large amounts of negative feedback are ofter detrimental to audio circuits and there is no reason that the power supply circuits should be free of these conserderations. 4. Most regulated supplies have an inductive output impedence that is parallelled with a capacitor for high frequency stability. The more feedback in the regulator, the lower this inductance is. This makes it even harder to get good stability at high frequencies and makes the particular choice of output capactor critical. 5. At the frequency the the output inductance and output capacitor have the same impedance resonant circuit is formed the freuency and Q of this resonant circuit can be very important. Add the self resonant frequency of the output capacitor and resonances of small value bypass caps to this and you can have quite a mess to considerd in the design. 6. The Jung regulators can be probamatic with digital and D to A circuits because this resonances are more easily excited by the large high frequency currents. The new designs are even more difficult to optimize due to the stabilty compromises made in the quest for low impedance numbers. 7. I hope this will dispell the notion that we are dealling with DC here as a voltage regulator is really a high speed amplifier with a capacitive load and a big DC offset. These factors are also important in three termimal regulators and that devices from different manufactures are audibly different is no suprise. Try the JRC regulators by the way. Also experiment with many different values and types of output and input bypass caps. Just a regulator guy, Fred |
#13 | |
Electrons are yellow and more is better!
Some regualtor can't take too heavy capacitive loads, consult the datasheets, they can tell you a lot.
/Per-Anders (my first name) or P-A as my friends call me |
#14 |
Hello Per,
We are talking about the 78xx series here and 2200 uF is overkill. 2200 uF is more likely to be used before the regulator. Please see the datasheets for proof/ evidence or whatever it takes to believe it. In cdplayers the load is mostly non constant. I modified tens of cd players by changing the 1000 or 2200 uF caps behind 78xx series regulators and they all had better regulation afterwards. Especially the old Pioneer players have these outrageous values. Another thing is that in a lot of players the output cap is placed too far from the regulator. I place them directly on the pins of the 78xx. Example : in the very good Marantz CD80 caps are about 10 cm away from the regulator. Change that and the player will have better regulation and less garbage on the supply lines. Check the 5 V supply to see what I mean. The Marantz CD 60 SE is a good example. K.I. replaced all the original caps with the same value Cerafine ( 220 uF ). In this case 220 uF was too much. Sound was going from left to right in volume. I placed 100 or 10 uF and the problems were over and sound was better too. Controversial thing: in digital OSCON behind the regulator is very good. In analog they sound worse than normal electrolytics. Does somebody experience the same with OSCON ?
It's only audio |
#15 |
Banned
Hi All,
Very well said Fred! As a illustration I found the following application note while cleaning up a pile of papers: http://www.onsemi.com/pub/Collateral/SR003AN-D.PDF (Compensation for Linear Regulators) |
#16 |
Fred,
... oh and before i forget it, i printed your 7 points and put it in my paper keep file.
Greets, Bernhard |
#17 |
Fred, a couple of naive questions.
*Would you agree that the job of a power supply is to provide stable DC under all operationg conditions of the powered circuit? *And that the PS is doing its job if nothing but stable DC appears on the power rails when the powered device is in operation (whether playing music or test tones)? TIA |
#18 |
diyAudio Retiree
Yep.... That's it's job all right. The problem is trying to do it in the presence of input signals from AC line variations, RF interference, voltages from the rectification of AC voltage to DC, and signals from the signal currents through the impedances on the input side of the regulator. At the same time the regulator is trying to maintain a very small AC error signal in the presence of the current demands of the circuit that it is regulating. Throw in the fact that the voltage reference for the regulator is being affected by all these factors as well as it's own zener or bandgap noise voltage contributions.
It sounded like a cushy job in the classifieds but it sounds like really having to work hard for a living to me. Power supplies are as difficult to get right as the audio circuit they are regulating. PSRR decreases with increasing frequency for feedback circuits and is zero for many no feedback circuits. I'm not sure I answered your question, but I am not quite sure of what the point is that you are trying to make. Fred http://www.diyvideo.com/forums/showt...age+regulators |
#19 |
No real point. Your post with a whole laundry list confused me a bit- it struck me that what a PS should do is actually rather simple and that once you have DC, it's DC.
Oh, yes, and that clearly the original questioner's power supply WAS doing its job, and if he was "hearing" differences in the absence of anything significant showing up on the rails with either regulator, the problem was more likely to be psychological than electrical. |
#20 |
Hi SY,
yes, I did see flat line on my "20MHz" scope, but I can sure you that life above 20MHz is much more "interesting". And if I have a spectrum analyzer. wow, I can sure that power rail is not steady as rock, instead I expect to see firework displayed to them. So DC is NOT DC... and power supply does make a huge difference. Actually, we are not "amplifying" a signal, instead we are using the power on the power supply to "replicate" the input signal and get an output hopefully similar to the input one. Good water make good wine, bad water make bad wine. It is that simple ... (of course not, but the basic is the same) |
| When to use 317 and 7805? | Sunsun22 | Power Supplies | 8 | 6th April 2009 06:47 PM |
| PSU with Multiple 7805 // | Ciu | Power Supplies | 5 | 24th March 2007 03:46 PM |
| 7805 trouble | DragonMaster | Power Supplies | 4 | 23rd October 2005 02:38 PM |
| Very low noise 7805? | ChuckT | Digital Source | 34 | 15th October 2005 02:47 PM |
| LM1085: low noise vs stability? | patwen | Digital Source | 8 | 29th October 2002 10:12 PM |
| Page generated in 0.12353 seconds (82.88% PHP - 17.12% MySQL) with 11 queries |
