diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Marantz CD-7 audio output mod. (http://www.diyaudio.com/forums/digital-source/71981-marantz-cd-7-audio-output-mod.html)
D.A.R.R.Y.L. 17th January 2006 08:29 PM
Hi All,
Having succesfully modified the output of my denon 2900 with two Mundorf Supreme Silver/oil 1F's I am willing to try to mod the output of my Marantz CD-7 also.
The cd-7 already has a Tent XO2 with XO supply, but I love what the cap change on the denon did, so I am willing to try it on the cd-7.
Included are the schematics of the parts concerned with modding the output of the CD-7.
From the HDAM (Marantz opamps) the signal, we take left channel as a guide, passes through R718 and then through the Elna's I want to replace, through relay L702 and then straight to the XLR connector.
I can not remove the caps and replace them with a wire, as I measured 0,5volt DC over these caps. So they definitely serve a purpose as to remove the dc component.
I was handed a formula to calculate the actual value needed for the replace cap, dictated by the lower cutt-of freq needed (in the order of 5 Hz) and the input impedance of the amplifier connected.
For the denon 2900 I calculated that 1F would suffice due to the extreem high impedance of my Electrocompaniet ECI-4 of 330 Kohm.
Can I do the same for my xlr connected CD-7 to the same amp, or should I be concerned with the dc component of 0,5 volt over the two 220F caps? Will a 1F (Mundorf Supreme Silver/oil) as a replacement be able to also remove this dc component? Or will any cap remove this component? Or is there a formula for which cap value removes what dc component?
Thanks a lot!!
http://home.versatel.nl/marantz/cd-7...c-coupling.jpg
http://home.versatel.nl/marantz/cd-7...muting_xlr.jpg
http://home.versatel.nl/marantz/cd-7...output_pcb.jpg
jean-paul 17th January 2006 09:39 PM
Re: Marantz CD-7 audio output mod.
Yes.
Yes.Some have more leakage than others. Electrolytics are the worst for this purpose ( in general ).
No.
Please do not forget R720 in your calculations for the correct value for the capacitor.
f=1/(2xPixRxC). This is the -3dB point. So 100k parallel with the amps 330k = 76,7 kOhm
1/ ( 2 x 3,14 x 76.000 x 1exp10-6 ) = 2 Herz
X.G. 17th January 2006 11:32 PM
hi, D.A.R.R.Y.L.
could you share me the schematic and PCB layout papers of CD7?
thanks a lot.my email box is jmxg007@tom.com
X.G.
D.A.R.R.Y.L. 18th January 2006 08:14 AM
Hi Tom,
Thanks for your advise Jean Paul!
It is 6mb in size, can your mailbox handle this?
jean-paul 18th January 2006 08:29 AM
My mailbox can handle that ;)
D.A.R.R.Y.L. 18th January 2006 08:31 AM
And your e-mail is?
jean-paul 18th January 2006 08:40 AM
I have sent you a PM....
D.A.R.R.Y.L. 18th January 2006 10:29 AM
Jean Paul,
is there any danger in changing the output with regards to killing a HDAM?
jean-paul 18th January 2006 11:18 AM
Not really if you don't short things.
D.A.R.R.Y.L. 18th January 2006 07:17 PM
Ok thanks I will give it a go.
Regrads,
Ramon
Resources saved on this page: MySQL 18.75%
