Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th January 2006, 12:17 PM   #1
jeff mai's Avatar
Default No display Marantz CD75II
This player is similar to a Marantz CD65II or Philips CD473.
I get no display - no buttons work. Voltage is present on display board. I tried a different front panel - same problems.
This occurs after installing a new clock. I've installed quite a few clocks in players without problems. There was a different aftermarket clock in this machine that was working fine.
Anyway, I'm just wondering what sort of failure mode this might be. Bad uP? Bad clock signal? The latter usually is accompanied by strange spindle motor activity which is not happening.
What do you guys think?
Thanks,
Jeff
Old 17th January 2006, 08:16 PM   #2
jeff mai's Avatar
There is clock signal on pin 11 of SAA7220.
I've traced it to the display uP chip - MC6805. It is not getting power, nor is +5V being sent to the display itself. Other chips are getting +5V, so it must be a localised problem.
Old 17th January 2006, 09:12 PM   #3
jeff mai's Avatar
Nothing like causing your own problems...or having a public conversation with yourself.
A previously repaired PCB track (done prior to my ownership of the player) became unrepaired during the clock install.
Everything works a treat now.
Jeff
Old 18th January 2006, 02:05 AM   #4
Fin is offline Fin
Fin's Avatar
Hi Jeff
Well done on creating you own problem and then solving it.
I've got a Marantz CD60 with a dodgy display. The right side is bright but gradually decreases in intensity to the left. Any ideas?
Fin
Fin
Old 19th January 2006, 08:38 AM   #5
Fidelity Audio's Avatar
Check the display voltage (vf1 and vf2).
Sounds like the heater elements are not getting enough voltage.
You sould have around 18-20V DC and 3-4V ac to the display.
Help!The display problem on Marantz CD94&CD95. kclai Digital Source 14 24th July 2010 10:17 AM
Marantz CD5000 - display very dull - help? audio_tony Digital Source 38 5th November 2009 08:03 AM
Marantz cd63 ki no display paul_peraic Digital Source 2 25th May 2008 05:22 PM
Schematics for marantz cd75II and philips CDM4 Alvinttt Digital Source 0 1st August 2003 02:48 AM
Page generated in 0.08234 seconds (66.89% PHP - 33.11% MySQL) with 10 queries
