| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
My Adcom DAC went down this week and I've been told right from Adcom 'good luck finding parts for it'.
It appears that the problem is likely the Ultraanalog digital receiver. Assuming I can't get one, how hard would it be to change it something a little more common? I'd appreciate if anyone could give me some leads tho. Jason |
#2 |
What comes after the Ultraanalog receiver?
#3 |
There was someone selling a UA rx.
http://www.diyaudio.com/forums/showt...ht=#post770852 |
#4 |
The UA is labeled AESC003.
The next chip has a sticker labeled OMICRON3, SPAL1R0 And then of course the next in line is the PMD100 HDCD decoder. What's the status on HDCD? Is it a dead technology now that microsoft took it over, or is it just an unadvertized part of the newer 24/96 and faster convertors? Jason |
#5 |
The omicron labled chip is is just a PALce16v8q PLC.
Jason |
#6 |
It is easy to connect a replacement rx to the PMD100 but if you want to retain the mutiple inputs you will have work out where the selected input enters the UA rx and you may also have to change the current input format of the PMD100. To that end perhaps Adcom will provide you with a schematic.
HDCD in its current incarnation seems to be available only as code for programmable DSP chips. |
#7 |
Adcom did provide a schematic. But's all they can provide.
The input switching is done through multiple relays before hand, and it looks like 1 pair of signal lines into the RX, the data lines through to the PMD100 and L + R data out to the DACs. Any hints on figuring which of the two is bad? I've got signal in before the RX, nothing out to the DACS. Just not sure what to look at between the two of them. Thanks Jason |
#8 |
What tools do you have? An oscilloscope would be nice but failing that do have any other digital IC's or dac chips or even a complete dac ?
#9 |
I've got a old 10meg scope.
Can I send you a copy of the schematic so we are looking at the same thing? |
#10 |
Banned
Oh boy.........you are going to need something faster than that.
Jocko |
| Fixing the R30 | bjackson | Multi-Way | 3 | 16th May 2010 06:10 AM |
| Need some help fixing this amp | mazeroth | Solid State | 1 | 13th May 2008 03:04 AM |
| Adcom GFA-585 went bad - calling Adcom experts | hangguy | Solid State | 14 | 24th December 2004 08:09 PM |
| Need Help Fixing an old NAD 304 | li_gangyi | Solid State | 14 | 8th December 2004 07:59 PM |
| Help! Fixing Amp. | shajan | Solid State | 20 | 29th May 2004 08:06 AM |
| Page generated in 0.09774 seconds (86.38% PHP - 13.62% MySQL) with 10 queries |
