Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th January 2006, 07:41 PM   #1
pixpop is offline pixpop  United States
pixpop's Avatar
Send a message via Skype™ to pixpop
Default TDA 1543 - How hot?
I've just finished my version of the DDDAC, with 8 x TDA1543 in parallel. I'm running them at 8 Volts, and they run warm, but definitely not hot.
Given the various designs I've seen, I expected they would get very hot - i.e. too hot - unless heatsinked. They don't seem like they need heatsinks at all to me.
The 8 of them draw about 350 mA total at 8 Volts.
How hot should I expect them to get?
Re reference voltage: Is the idea to set this to half the supply voltage?
Neil
Old 11th January 2006, 10:32 PM   #2
dddac is offline dddac  Germany
Default Re: TDA 1543 - How hot?
Neil
aprox 60-70 degrees.....
regards
doede
www.dddac.de
Happy listening and building
Old 11th January 2006, 11:13 PM   #3
pixpop's Avatar
--> aprox 60-70 degrees.....
Do you mean Celsius, or Farenheit?
I would say they are about 40 Celsius. I think about 50 Celsius is when things become too hot to touch, and these are way cooler than that.
BTW, they work fine, and the DAC sounds great, I'm just puzzled about the lack of heat.
Neil
Old 12th January 2006, 12:39 AM   #4
pburke is offline pburke  Germany
what voltage are you feeding them? Doede's design is asking for 8.5V and that will make it 70 degrees Celsius easily
Peter
Old 12th January 2006, 12:41 AM   #5
on second reading of your post - 8V is close - should be hotter. And 350ma for 8 of them is too low. I see about 2 amps with 16 of them. are you sure all 8 are connected to the circuit, especially the power pins?
Peter
Old 12th January 2006, 12:50 AM   #6
Banned
Peter
Some years ago, when I made my first TDA1543 dac, with single chip (sounds better than paralleled, but that's another story) and 8V PSU voltage, the dac got a little hot to touch.
As I had a handfull of them, and the chip was on a socket, I started changing dacs.
To my surprize, and always with 8V PSU, nothing changed, some TDA1543 chips got hot, others just warm, and others really cool.
I kept the chip that runned cooler, and I mean really cool, ambient temperature.
Old 12th January 2006, 01:55 AM   #7
pixpop's Avatar
--> are you sure all 8 are connected to the circuit, especially the power pins? <--
I just double checked, all of them read 8.05 Volts on my Fluke DMM. One difference I have is that the chips are connected to a ground plane, rather than stacked in a tower. Perhaps that is sucking away some heat, or perhaps I just have 'cool' chips.
Old 12th January 2006, 02:31 PM   #8
X.G. is offline X.G.  China
X.G.'s Avatar
I had tried the 4 pcs of TDA1543 (construction like a tower) in 8V. a few minutes after power on,I heard the sound of dirtortion.I changed them in 7V,and solve the problem.
Old 12th January 2006, 08:11 PM   #9
pixpop's Avatar
OK, I just realized part of the problem. I've been doing my temperature testing with zero data. I think this turns off all the DAC switches, and gives the highest output voltage.
When I get home tonite, I'll set the data to all ones, so all the DAC switches should be on. I think this should give me the maximum dissipation, and the lowest output voltage.
Old 12th January 2006, 08:28 PM   #10
this is not the "solution" to the problem. The chips draw aprox 50mA each, regardless of sound is played or not.... so each chip dissipates 8 x 50m = 400mWatt. 8 pieces --> 3.2 Watt.
If they are stacked in a tower, they get hotter, than when each chip can radiate its own heat in free (cold) air, as you assembled the chips next to each other didn't you mention ?
doede
www.dddac.de
Diy-dac 1543 Tolu Digital Line Level 112 9th September 2009 12:20 PM
first try cd-rom + 1543 dac senderj Digital Source 17 29th September 2006 01:37 PM
DIY USB-1543 Dac Kit Help recca Digital Source 7 26th August 2005 05:55 PM
Tda 1543 Chris Digital Source 5 23rd October 2003 10:39 PM
Page generated in 0.11050 seconds (78.42% PHP - 21.58% MySQL) with 10 queries
