| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
For matched Quads, I think that Analog devices MAT-04 would be your best bet. In fact, using 2 of Analog Devices' MAT-02 would probably be a better match than 1 Quad from Motorola's quad line.
_______ Brian |
#22 |
Brian> You are right if the Application is small signal like a Diff Amp I have used Mat-02's and MAT-03's as Diff Amps in Discreet component Headphone Amps, However the Motorolla Devices I use have Higher Current ratings and I use them as as Output Stage Buffers in Some of my Headphone Amp Designs and thay take up alot less space than separate Transistors Plus having Both PNP & NPN types on the same Chip greatly improves thermal tracking.
#23 | |
_______ Brian |
#24 |
See Attached Schematic of my pocket battery Operated unit. If discreet component is what you want post I will try to attach but it is a large file and may not attach
#25 |
stadams:
>I have searched for a data sheet for the 2SC3381< 2SC3381 & 2SA1349, data sheets, zipped pdf format, separate files per page because of filesize limitations. Hope this helps, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com |
#26 |
nm
#27 |
nt
#28 |
Thanks for the info.
-Todd |
#29 | |
did you compare linear systems' transistors with Japanese originals ? and what did you find out ? regards, Hartmut from Munich |
#30 | |
UrSv Those who say it can't be done should not stop those who are doing it. |
| Matched PNP/NPN dual transistors | carlmart | Solid State | 31 | 25th January 2012 10:36 PM |
| Adding more transistors to output stage? | bowdown | Solid State | 6 | 19th January 2007 07:15 PM |
| Has Anyone else used MJE13005's Switching Transistors for the output stage. | John Biles | Solid State | 30 | 3rd September 2005 06:02 AM |
| 5 transistors output stage | KCC | Solid State | 6 | 30th June 2003 01:52 PM |
| 50 Output Stage Transistors? | thylantyr | Solid State | 22 | 26th April 2003 10:44 PM |
| Page generated in 0.09698 seconds (82.16% PHP - 17.84% MySQL) with 11 queries |
