Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th January 2006, 08:41 AM   #1
toman_9 is offline toman_9  Germany
Default Marantz CD-38
Hi!
Since my Philips DVD player which was serving as CD player for the last years is dead... Now I am back to my dear old friend Marantz CD-38.
I have to admit that the performance is not that brilliant, as I am in progress of upgrading my amp, I am in need of a decent CD player as well. Therefore I would like to upgrade my Cd-38.
I read that there is a AH! Tjoeb'99 design which basically re-invents the Cd-38, while keeping the CD drive and replacing the DAC and the analuge parts. Unfortinately they do not offer any upgrade kits.
I would like to do it the same way:
Keep only the CD drive/micro and upgrade the DAC, analog parts and the power supply.
Does anyone have similar experience w.r.t. power supply and DAC upgrade ?
Are there any DAC KITs available ?
Meanwhile I am searching for the I2S lines inside the CD player,
does anyone have the service manual ? Or give me a hint which lines they are.
Thanks!
Old 9th January 2006, 10:38 AM   #2
I have seen Doede's DAC (www.dddac.de) and it seems very reasonable design, and he offers PCBs as well.
So I might go for it for my DAC upgrade.
DDAC uses 12v power supply, since I have read in the forums that, the power supply has a very important role inside the DAC designs, I would like to have a high quality power supply.
Can anyone suggest a good power supply KIT ?
May be Doede has a suggestion which power supply to use, I couldn't find (YET) on his web site.
Thanks.
Tim
Old 9th January 2006, 11:50 AM   #3
dddac is offline dddac  Germany
Default dddac power supply
Thereason you have not found a power supply on my website is that I use, with good results so far lead batteries. The ones the yuse in Alarm systems etc, maintenance free types...
This solution is cheaper and as good or better then regulated low noise power supplies....
any way, I tried from some dddac-builder once a power supply with a good transformer, schotkey diodes, large BG capacitors and a MOSFET sourcefollower. This was a very good solution and sounded very very good. at least as good as a battery. May be on small details a bit better But realize, this is not a cheap solution ......
May be I should build one, listen and publish as example....
regards
doede
www.dddac.de
Happy listening and building
Old 9th January 2006, 12:52 PM   #4
Hi Doede,
Thanks a lot for your reply!
Yes I have realized that you have used batteries, and I am sure that they produce very good results indeed.
However my intention is to "upgrade" the existing CD player, but not to build a stand alone DAC.
If I can get a power supply within a reasonable budget, then fine.. if not then worst case I will use the internal power supply that is already built in my CD player.
Marantz CD-73 Edo33 Digital Source 1 31st May 2011 01:19 PM
Marantz cd-32 ObliVion Digital Source 3 15th July 2007 09:25 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 03:21 PM
Link Between Marantz CD12 and Marantz CD99 Mesh Digital Source 16 7th November 2003 06:08 PM
Marantz T-1 stigla Tubes / Valves 4 17th October 2002 01:11 PM
Page generated in 0.08279 seconds (74.63% PHP - 25.37% MySQL) with 10 queries
