Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th January 2006, 04:23 AM   #1
Default CD players SKIPPING... each is worse than the other
I have a couple CD players I have been swapping in the effort to find one that doesn't skip at high volumes...
Old Sony... the worst
Pioneer 5 disk player... so so
Some Technics 100 disk thing I stole from my son... as bad or worse
I have tried several strategies of foam, bricks, tennis balls with little objective results.
Best so far... by a major factor is an A-Open 32X running off an AT power supply. Ugly, but when you want a lot of music, it is less susceptable to skipping at high volumes.
I would invite any recommendations for a more robust and less vibration prone CDP.
Old 5th January 2006, 06:19 AM   #2
analog_sa's Avatar
Are you running a dance studio? I've never witnessed volume related skipping on my Teac P-700 and don't believe it's even possible with this unit.
Of course you shouldn't delegate vibration isolation to just the cd player. Are you using a rack/support with any abilities in vibration control? Cones, ball-bearing, air-isolation? I suspect not if you get to extremes such as skipping.
Old 5th January 2006, 03:08 PM   #3
I'm not running a dance studio, but sometimes I like to heat it up a little. Just a LM3875, two line arrays, and two Tuba18's with 100 watt plate amps.
Better dac = worse TV sound? sharpi31 Digital Source 0 11th December 2008 09:29 PM
Bad Car Amps Gone Worse... sousmielie Car Audio 25 28th June 2008 10:39 AM
I must have the worse luck - Clarion EQ pityocamptes Car Audio 7 10th December 2007 02:26 AM
sacd better/same/worse dvd-a??? aaronboumans Digital Source 20 27th February 2007 06:36 PM
Page generated in 0.06222 seconds (71.32% PHP - 28.68% MySQL) with 10 queries
