Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th January 2006, 01:19 PM   #1
Default Denon 2900 clock supply hookup.
Hi All,
I was wondering where to hookup the XO supply for my XO3, so it will be switched on at the same time the 2900 switches on?
Guido advised to use this config for the clock to always work correctly.
I now have the XO supply permanently on, and this does not work all the time.
I have the pdf format service manual.
Thanks in advance.
Kind regards,
Ramon
{Marantz CD-7 Guido Tent Clock ---> HMS Sestetto MKII XLR ---> Electrocompaniet ECI-4 ---> Kimber 8TC ---> Eros MKII DIY}
Old 4th January 2006, 02:45 PM   #2
A 8 is offline A 8  Sweden
You could use the existing clock powersupply to drive a relay that then could switch your XO supply on and off at the same time.
Old 5th January 2006, 03:42 AM   #3
georgehifi's Avatar
Send a message via MSN to georgehifi
D.A.R.R.Y.L. you could solder the mains input of the XO Supply to the primary (mains) of the Denons mains transformer, this way when the Denon is swiched on so is your XO supply and XO3.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 5th January 2006, 09:24 AM   #4
That could potentially work but you are likeley to get the timing "way" off as the ps supplies are very different.
There is timing logic for groups of ps supply in the denon. Doing what I suggest gets you very close to keeping the original startup times. This way has worked everytime in many of my ps modifications in various players.
Old 5th January 2006, 10:27 AM   #5
Would you advise a relais between the XO supply and the clock (22 volt line) driven by the original clock voltage? This seems faster to me because the XO supply is already at 'operating speed' the whole time.
Or would you advise to put a relais between 220volt and the XO supply, driven by the original clock volatge?
Thanks.
Old 5th January 2006, 12:54 PM   #6
I dont know what kind of xo supply you have but to get the timing right you should control the 3.3v feeding the clock.
Its probably easier to avoid "dirt" finding its way into the 3.3v supply if you apply the relay at the 22volt feed but if this supply then is slow to start up you might still have a problem.
Unless the clock supply is very slow to get to the right voltage you could also probably let the 220v feed run off the main power off/on switch as well.
Denon 2900 clock upgrade? simeon_noir Digital Source 9 15th January 2008 08:10 AM
Denon 2900 strange clock behaviour D.A.R.R.Y.L. Digital Source 9 25th December 2005 12:26 PM
Best method of replacing denon 2900 clock D.A.R.R.Y.L. Digital Source 6 2nd December 2005 05:01 PM
Page generated in 0.09638 seconds (73.20% PHP - 26.80% MySQL) with 10 queries
