Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st December 2005, 11:39 PM   #1
Default DEQ2496 latency
Integrating a DEQ2496 as a subwoofer EQ and want to properly integrate it into my system (it's in the chain after the receiver) ... two questions ...
(1) what's the latency / delay of the unit?
(2) what would that correspond to in terms of "feet" ... so that I can adjust the receiver's setting for relative distances of the speakers to account for the extra time delay in the Behringer?
Old 5th January 2006, 02:56 PM   #2
Pulse-R is offline Pulse-R  Australia
The delay is in the order of about 1ms or so (depending on what you're doing internally), that's bout 34.5cm or 1' 1.5"
problem I have is the EQ only goes down to 20Hz, my sub plays below this, but needs a little EQ around 16-18Hz. Unit is good for ADC + EQ
Digital is only on or off
Old 5th January 2006, 09:56 PM   #3
seoman is offline seoman  Netherlands
around 16-18Hz
How can you know? RTA stops @ 20Hz.
Why not shift the sub arround the room to get the <20Hz correct.
And then do the > 20Hz with the DEQ.
Still i wonder, how can you tell if it's correct.
Simon
Old 8th January 2006, 06:28 AM   #4
Hi Seoman
I use SpectraRTA software on a PC to measure RTA down to 10Hz.
and this is in the car, not the lounge, so moving the sub around is a bit awkward
seasons greeting too
Simon
Low latency room correction + xover in mini-itx fb Digital Source 8 22nd May 2008 10:50 AM
Sound card calibration part II - Variable latency anyone? NIC1138 Digital Source 0 6th June 2007 11:29 PM
latency - throughput delays peace brainerd Digital Source 3 28th March 2007 07:50 PM
Receiver Latency ? percy Digital Source 0 2nd October 2006 01:22 PM
Amp supervisor circuit latency rborer Solid State 9 7th November 2002 06:12 PM
Page generated in 0.07250 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
