| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Does the OPA627 need coupling caps? Or can I get away with just a resistor? I have been using AD8620 with just a 100ohm resistor on the ouputs with great success. If caps are needed, whats the best sounding route to go?
#2 |
if memory serves me right, the OPA627 is FET input, correct? the offset figures, while not as low as AD8620, are probably still very low. most any FET input opamp will be fine i think, but you will want to measure it to be sure. if it's above, oh, 10mV or so, you may want a blocking cap.
i'm using AD8620 in my modified C222ES SACD changer. it's transparent, but i think it can sound a little thin in some applications. in my Panasonic DVD player it is very bright i may want to give the OPA2132 a shot. |
#3 |
nope.. 50 uV worst case.. and better to my ears than 8620, at least for the dil packaged 627
i am currently using 60,000 uF of capacitance in my preamplifier.. |
#4 | |
| RCD-965BX / OPA627 - Class A Bias & O/P Coupling Caps | poozebear | Digital Source | 6 | 13th July 2007 11:59 PM |
| I looking schematic of Class A tube stage for 999ES | ccontreras | Digital Source | 0 | 3rd May 2007 03:28 PM |
| Coupling cap.question.. | Dxvideo | Chip Amps | 20 | 1st December 2006 03:34 PM |
| Coupling cap question | Simpleton | Tubes / Valves | 10 | 6th June 2005 01:32 PM |
| Page generated in 0.08667 seconds (69.93% PHP - 30.07% MySQL) with 10 queries |
