Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th December 2005, 07:29 AM   #1
Question Newbie AES snake cable questions
Im gonna try to wire up a multichannel AES snake to connect my Tascam DM24 digital mixer to my new Dynaudio Air20 digital monitors (5 satellites and the Air Base2 sub), thus requiring 3 XLR male ends (plugged into the master speaker) to correspond correctly to particular pins on the male D25 connector plugged into the mixer. I have attached a jpg of the AES pinout that Tascam uses in the mixer card in question.
I have some newbie questions that may seem silly, so bear with me.
The tascam pinout diagram shows 3 pins associated with each input; G, C, and H.
What do the letters stand for? (ground, cold, hot?)
The Belden multichannel AES cable I am going to use has 3 strands in each casing; black, red, and bare.
What color should be soldered to which pin on the d25 connector? (bare to G, Im sure)
What color should be soldered to which pin of the XLR connectors on the other end?
If I reverse the red and black wires on the XLR connector, will the "left" and "right" be reversed as well, or does digital not work that way?
Is 1 mm lead-free rosin-core solder appropriate?
Thanks in advance.
Old 28th December 2005, 07:44 AM   #2
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Good evening,
You are correct,
G=Ground
H=Hot
C=Cold
On the belden cable,
Bare=Ground
Red=Hot
Black=Cold
On the XLR,
Pin 1=Ground
Pin 2=Hot
Pin 3=Cold
The type of AES you are using is balanced, just as if you were sending balaced audio down the cable. If you reverse pin 2 and 3 your signal will be out of phase. You don't want it to be out of phase. Btw, you are using 110 ohm cable right?
Old 28th December 2005, 01:24 PM   #3
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
AES is biphase encoded; will work fine if pins 2 and 3 are reversed.
Old 28th December 2005, 04:37 PM   #4
Btw, you are using 110 ohm cable right? [/B]
Yes indeed.
Old 28th December 2005, 04:43 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Wink Not that you would....
It'll work, but it won't be fine, the phase will be reversed.
You've got the chance to keep polarity (phase) as original, it would be foolish to throw that away.
Old 28th December 2005, 06:07 PM   #6
Banned
No, the phase will not be reversed. Only after the SPDIF RX chip can you reverse phase.
BTW.......sorry you are stuck using an AES cable. Lots of reflections on all of them. XLRs make lousy RF connectors, evern if their characteristic impedance is 110 ohms.
Jocko.
Old 28th December 2005, 06:29 PM   #7
gmarsh's Avatar
Jocko.
I was waiting for you to show up in this thread
Old 28th December 2005, 07:57 PM   #8
Banned
Yeah....you knew I would find it. Eventually.
Send me an e-mail, and I'll tell you more of the ASRC story.
Jocko
Old 30th December 2005, 04:49 PM   #9
dhaen's Avatar
Oops, I missed the AES Sorry for any misguidance.
Adjustable spdif cable? smells like snake oil to me. OzMikeH Digital Source 10 8th February 2008 09:54 PM
Questions about making Cat5 speaker cable wixy Everything Else 1 10th March 2007 07:57 AM
snake cable - drain wire connects to..?? redrabbit Parts 5 9th August 2006 05:42 AM
MC phono cable questions (Long) phn Analogue Source 6 26th December 2004 07:22 PM
Few Gc questions from newbie rs1026 Chip Amps 1 31st October 2004 04:04 PM
Page generated in 0.10819 seconds (84.57% PHP - 15.43% MySQL) with 11 queries
