| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
anyone modified this player? It seems to have quite a competitive chipset on board and I'm thinking about buying it, especially as it is usable as DAC. Thanks Stephan |
#2 |
Hi - I just bought one a week ago:
Initial listening results are a dissapointment: dull and poor dynamics - Little depth and not very engaging - although detailed. My 'old' machine is a modified Marantz CD 63 with AD 826AN Op-Amps - Chosen for their clarity, depth, dynamics etc.. Fantastic amps as long as they are properly bypassed on the supply lines as they are fast!. Cant detect oscillation upto 25Mhz (my 'scope limit) I compared them with BB OPA 2604 and OPA 2134 neither of which I liked: The OPA 2604 colored the sound and was overly "bassey" - the OPA2134 was tiring to listen to. I have built Elliot pre amp / phono pre-amp and Linkweitz-Reily 3 way electronic crossovers with AD 826AN and they sound fantastic. OK - I should have read the service manual for HD 970 First - but it does have some interesting elements - e.g. the I/P select to use the DAC. I think that with AD 826AN - op-amps replacing maybe all the BurrBrown offerings it might do the trick. As I have binned all the original packaging I am commited to get the thing to sound good. Watch this space. The rest of my system is fully tri amped using ESP P3A power amps (3 amps per mono-bloc) / channel and sounds fantastic - nice one Rod! |
#3 |
I have replaced all elcaps with Black Gate FK, NX, and PK. Hard to remove the big PSU caps since they are glued! I also placed a lot of vibration dampening inside. After the usual BlackGate burn-in-time (50+ hours) there is a clear improvement with more attack in transients and a more open soundstage. The bass is also tighter. I am now contemplating changing the OPA2134s to either AD8620 or THS4032. The supply is 12V according to the service manual, but I don't know the gain (THS4032 needs minimum Gain=2).
#4 |
Some measurements for HD970, here is very small place for objective improvements.
Before mods After mods Objective parameters, especialy THD and jitter are excelent. |
#5 |
Hi Leolabs,
Where do you get this? I have the service manual. The output stage is a discreet diamond buffer. Regards. |
| Harman Kardon AVR 10 | halloweenguy | Everything Else | 6 | 1st February 2010 06:52 PM |
| Harman Kardon HK 770 | argonrepublic | Solid State | 17 | 7th November 2009 05:45 AM |
| Harmon Kardon HD970:inside view | Leolabs | Digital Source | 27 | 20th August 2007 03:26 AM |
| For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck | electric blue | Swap Meet | 1 | 26th August 2006 12:36 AM |
| Harman-Kardon PM 665 | sangram | Solid State | 1 | 17th May 2006 07:32 AM |
| Page generated in 0.10758 seconds (70.64% PHP - 29.36% MySQL) with 10 queries |
