Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th December 2005, 12:49 AM   #1
jovan is offline jovan  Yugoslavia
Send a message via ICQ to jovan
Default CDM1, or CDM4 pro, or CDM4/21
Hi everybody!
First i want to say-Sorry about my english,it's not as well as i would like to be.
Well, i have a little problem, and i don't know anything about electronic, it means that i need a help of all of you;
I have Meridian 200 transport, and i think that it's laser is at the end of life , because often it has problem with skiping, or it doesn't want to read some of cd-rs for a couple of minutes when i put cd inside.Problem is in the fact that i have trouble to detect Philips transport in it.Somebody told me that it is cdm1, somebody cdm 4 pro, third person told me: "cdm 4/21!"
Does anybody knows what is the right answer ??
Also i have Rotel rcd 855, with good transport, i think cdm4...So, is there any chance to change these two transports between Meridian and Rotel, if in Meridian is cdm4/21, or cdm4pro??
Old 25th December 2005, 05:29 AM   #2
Hi Jovan,
The Meridian 200 use a CDM 4(don't know exact version)
Meridian 602 use a CDM4/36 pro(all alu casting)
And your Rotel 855 use a CDM4/19
Praudio
Old 25th December 2005, 10:25 AM   #3
Thanks a lot!!!!!!
I'll try to find that transport, before my totaly die
Old 26th December 2005, 08:52 PM   #4
tubenut is offline tubenut  South Africa
tubenut's Avatar
Many posts say the CDM4 optics can be built across between various incarnations of CDM4. I believe the differences are in the actual block and motor, not the swingarms...
Search on this topic...
Old 26th December 2005, 09:01 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Aligning the swing arm is something I won't do, not unless the CDM-4 is easier than it's earlier cousins.
-Chris
Old 27th December 2005, 12:32 AM   #6
guido is offline guido  Netherlands
guido's Avatar
-Chris
No alignment needed, indeed much easier than the cdm0/1. And it can be done without much problems (been there). Search here, many posts on this subject.
So get yourself a (cheap) playing philips and swap the laser. Look at your local second-hand shop and google the players you see there.
But maybe it is not the laser
GuidoB
Old 27th December 2005, 05:27 PM   #7
anatech's Avatar
Hi Guido,
Thanks, I may give it a shot. I find the disc motor is usually shot.
I still have memories of hours and the glass disk on the CDM 0 & 1. That and the suspension for the lense may sag on those.
-Chris
Old 27th February 2008, 02:33 AM   #8
Default Meridian CD200 CDM
Hi. In the CD-200 transport Meridian only used the Philips CDM4/21 mech. Meridian have had no 4/21's for many years. If the laser has failed the laser from other CDM4 series mech can be used in the 4/21. Hope this helps!
philips cdm1 pro and cdm4/11 LeoJar Digital Source 8 7th October 2008 08:26 AM
Wtb: Cdm4/36 Isaac Sibson Swap Meet 1 25th March 2007 11:54 PM
Cdm4/19 halewood Parts 1 26th October 2004 06:08 AM
CDM1 motor in a CDM4/19 ??? Lyra Digital Source 1 1st March 2004 02:36 AM
Repairing CDM4/19 (with CDM4/31???) Shaun Digital Source 4 1st August 2003 01:29 PM
Page generated in 0.11673 seconds (65.89% PHP - 34.11% MySQL) with 10 queries
