is that grounding any good???? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd October 2002, 10:14 PM   #1
weissi is offline weissi  Europe
weissi's Avatar
Default is that grounding any good????
please only look at the ground plane, signal and power was routed very quickly ;-)......
regards / servus
Old 24th October 2002, 12:05 AM   #2
MRehorst's Avatar
a schematic and some key as to which parts are which on the layout would help...
MR
Old 24th October 2002, 02:44 PM   #3
weissi's Avatar
its a layout for an pcm1716, but that´s not of interesst as I wrote it. What´s important for me is, are the via´s between solder and bottom ground layer any good? I mean, normally 2 ground layer´s aren´t the best, but i thought that "some" via´s could solve the problem of differentail voltages and currents between them...... AND: ground planes look sooooo professional ;-), beside that my etching solvant holds longer cause fewer copper to remove......
thanks...
regards / servus
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 09:50 AM
grounding yulquen Digital Source 0 30th December 2006 07:56 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 10:27 PM
Copyright ©1999-2017 diyAudio
