Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
PGA2310 & NE5532 get hot?
Old 18th December 2005, 08:40 AM   #1
sergiusz is offline sergiusz  Germany
Default PGA2310 & NE5532 get hot?
Hello,
I built a small test circuit using a PGA2310 and a NE5532 input buffer. The analog part of the PGA2310 and the NE5532 are powered with +-15V using LM317/LM337.
When I touch the NE5532 it gets pretty warm, tha PGA2310 gets hand-warm.
Is this behaviour normal?
Thanks in advance,
Serge
Old 18th December 2005, 09:28 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
A schematic would be handy, if possible.
/Hugo
Old 18th December 2005, 10:24 AM   #3
Sure,
attached is the schematic of the PGA and NE5532 part.
R3 & R6 are marked 0 and R4 & R7 nc (not connected), because I currently let the NE5532 run without any gain.
SV3 is the "bus" connector to the atmel controller. SV1 is the output bus for daisy chaining with a 74hc595.
Thanks !
Old 18th December 2005, 10:27 AM   #4
And here is the PSU attached.
Nothing fancy at all :-)
Old 18th December 2005, 11:09 AM   #5
Netlist's Avatar
Much depends on the environment and the definition of warm and hot.
Looking at the datasheet the dissipation is 1200 mW max.
I nothing is oscillating, I would believe this is fairly normal.
/Hugo
Old 18th December 2005, 11:40 AM   #6
Hmm ... oscillation, that may be it ... I have to admit I have no bypass caps on the 5532, shame on me.
On another thread I read that a small series resistor may be needed on the output of the opamp too.
I did not assume oscillation because the sound is not distorted.
Thanks for the hint anyway. I'll rework my design and improve the buffer stage,
Sorry for the newbish questions ;-)
Bye,
Serge
Old 18th December 2005, 08:51 PM   #7
Jocko Homo is offline Jocko Homo  United States
Banned
Just because it doesn't sound distorted.............
Get your 'scope out. Hope you have one. "Sounds" like you will need it.
(Sorry.......that was too obvious a pun to pass by.)
Jocko
Old 18th December 2005, 09:12 PM   #8
Sorry .. I'm a pretty newbie at this. I put bypass 100n caps from the supply pins to ground as well as 250Ohm resistors on the output. Well, the ne5532 still gets warm.
I do not have a scope unfortunately. Is there any other method of detecting oscillation?
Thanks,
Serge
Old 18th December 2005, 09:39 PM   #9
Netlist's Avatar
A trick might be to calculate the power consumption at idle and look if it's within specs. If notů
Also, assuming you have taken the necessary precautions to prevent the circuit from oscillating you could be on the safe side.
But then again, you are never sure without a scope. Ebay might be your friend for your next investment.
/Hugo
Old 20th December 2005, 11:52 AM   #10
alfsch is offline alfsch  Germany
5532 gets warm, thats normal...30..35░
and the sound? idle noise?
PGA2310 & NE5532 get hot?Hide this!Advertise here!
Upgrade for NE5532 diy student Parts 78 15th January 2018 02:12 AM
NE5532 vs NE5534 rumblinbass Parts 9 14th December 2007 03:24 PM
What about NE5532? rhavecilla Chip Amps 12 6th September 2007 04:05 PM
Ne5532 zahlm Parts 3 13th May 2004 10:22 PM
Suspicious NE5532 wxn Parts 22 13th February 2004 09:48 PM
