| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I just picked up a used DCD-1520 and would like to do some mods to it.
I opened it and found numerous op amps???I see NE5532 and NE5534's...Would I have to replace all of these??I know the 5534 is a single channel op amp and the 5532 a dual but can I get improvements without spending tons of money???Help! |
#2 |
Anyone out there???????????
#3 | |
Hi\ OPA134 resp OPA2134 are decent alternatives at very acceptable prives.You may want to upgrade the output coupling cap(s) and get rid of the muting transistors. Clock is also a good target to upgrade as wel as power supply diodes, I very much like Scottky Barier types. best |
#4 |
Thanks very much!I checked the prices of the Op amps..all very reasonable...What brand of Caps do you suggest??
#5 | |
Hi, For output I very much like the Audio Note copper folis, but these are bulky, and more expensive than all opamps together. But they are good ! Alternatives are polypropylene like Wima MKP10 - much cheaper. Power supply: Panasonic FC types Clocks: suit yourself. Many are discussed on this forum. As I am one of the manufacturers, I won't push you in certain directions. best |
#6 |
Electrons are yellow and more is better!
I have also a vintage DCD-1520 and my best advice is to let the CDP rest in pease. My is 17 years old with bad laser.
/Per-Anders (my first name) or P-A as my friends call me |
#7 |
DIY !
The Denon use a KSS 151A (Sony) laser, hard to find & expensive.
(I have a ok, used laser-unit lying around...) Arne K
Ars longa, vita brevis |
#8 |
Sorry to dredge up an ancient thread, but I will be getting one of these decks very shortly and I'm wondering if anyone actually did any upgrades after this thread ran and if so how they worked out? Any good sources for a spare laser (I'd like to put one aside if I can).
#9 |
I upgraded the heck out of a number of DCD1520's over the past few years. They can be made to sound quite lovely, but seem limited by the PCM64 dac chips. Could never get the kind of spaciousness and clarity that I get with players using PCM58/63/1702/etc.
Best source for replacement lasers is to buy older DCD1500II machines, which usually go pretty cheap. Anyone with new-in-box 151's is going to want three arms & two legs for them. But, in my experience, KSS151's have only about a 5% chance of failure, so I wouldn't sweat it much. |
#10 | |
So, which mods did you find most worthwhile? I have a Sony 608ESD of the same general period (more equivalent to the DCD-1500ii I think?) and ditching all of the clip connectors and hard wiring the boards together made a significant improvement along with some improved diodes in the power supply. What sort of thing would be good for the DCD-1520? I've seen reference to swapping out opamps and such, but I don't recall much for details about the results. |
| Denon DCD-1015 mods | alex108n | Digital Source | 22 | 4th October 2010 02:18 AM |
| Denon DCD-3560 Mods | edwardcr | Digital Source | 4 | 6th February 2009 07:18 AM |
| Denon DCD 1520 20-bit or 18-bit? | beauty_divine | Digital Source | 0 | 9th September 2007 06:41 AM |
| Denon DCD 1520 not recognise some disc | stoozo | Digital Source | 8 | 15th April 2007 09:28 PM |
| mods for the Denon DVD-3910 | cowanrg | Digital Source | 6 | 1st December 2006 07:36 PM |
| Page generated in 0.10752 seconds (79.62% PHP - 20.38% MySQL) with 10 queries |
