Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th December 2005, 10:13 AM   #1
sagarverma's Avatar
Default usb modification for survelliance.
i dunno how i forgot.there is this digital forum out here which can help.
i have a webcam(usb).i have modified it for night vision.
i wanna make the usb extend beyond 5mtrs. max range.
DIY solution req.bec ready made way too costly.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 16th December 2005, 04:47 AM   #2
sagarverma's Avatar
hey,better still.
how to make it wireless?
replies plz
Old 3rd January 2006, 04:46 PM   #3
sagarverma's Avatar
whats keeping u away guys?
USB mod required to make the cable extend beyond its 5mtrs range.usb cable of webcam is to be modded.anyone has technical info on USB i.e bout its wires,function of each wire,voltages etc.?
Old 3rd January 2006, 05:47 PM   #4
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Start here http://www.usb.org/developers
/U.
Old 4th January 2006, 06:05 AM   #5
sagarverma's Avatar
first of all thanks for reply
very good link.lemme see if it helps.
have u extended the usb length beyond 5mtrs?
Old 4th January 2006, 02:07 PM   #6
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
how long do you want the cable? If you need 10 meters, just use a longer USB cable or use extension cables and see if it still works.
If you need 100 metres, USB will definitely not work and you should look at using something like a PAL/NTSC video camera, a long length of good 75 ohm video cable (RG-59 or RG-6) and a USB video capture device instead.
Making USB wireless is almost impossible for a DIY project.
Old 4th January 2006, 02:48 PM   #7
sagarverma's Avatar
hi Gmarsh
i hooked up a 5mtr cable to webcam.so effective length=5.8mtrs.but on the flip side,the cam hanged a lot.again n again,it became offline(USB standard permits max 5mtrs and is sensitive to cable resistance).
i hooked another two mtrs,it stoped working!
i need atleast 25 mtrs.
i have seen very cheap but very good NTSC, PAl cams(wireless and have automatic switching b/w infra red and visible light capture).but how to connect them to my pc?i have a pixel view tv tuner card in pc,but the video size from it is .
i had in mind to use the above cam(it has tv a/v i/p and is wireless),give its i/p into pc tuner card,is it possible?
how can the video size be compressed dynamically(from tv tuner)?
webcam captures video at 1mb/min in 800*600 res.i modified it for night vision.how to make powered USB HUB to strech the wire to 30mtrs or so?
Old 5th January 2006, 12:21 AM   #8
neutron7's Avatar
theres a box called "usb extender" you can get that connects usb at both ends via cat5 cable.
http://www.networktechinc.com/usbc5.htm
maybe you can build something like that (or find on ebay). its brobably just line drivers/buffers inside.
and why is the reason that USB only works for certain distance? it must be the electrical properties of a normal USB cable, such as noise sheilding, resistance and capacitance etc. maybe you could just use a different kind of wire and extend it that way. it might be worth trying anyways.
Old 5th January 2006, 08:39 AM   #9
sagarverma's Avatar
the prob is USB specification which permits only 5mtrs,reason being sensitivity to cable resistance.
usb extenders r available,i.e powered USB hubs,but they r way beyond my budget.
**link inactive**
Modification..... Actuary Tubes / Valves 3 26th February 2008 01:34 AM
X-over modification hermanho Multi-Way 1 20th February 2006 06:52 AM
Help CDP-Modification wfmali Digital Source 0 1st June 2003 05:03 PM
Help with CD modification primalsea Digital Source 1 20th April 2003 08:06 PM
Zen modification tschrama Pass Labs 8 29th December 2002 05:59 PM
Page generated in 0.09805 seconds (76.88% PHP - 23.12% MySQL) with 10 queries
