Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th December 2005, 10:17 PM   #1
Send a message via AIM to sr20dem0n
Default s/pdif, fixed or floating
Anyone know if s/pdif uses fixed or floating point? I can't seem to find the answer
Old 13th December 2005, 10:22 PM   #2
Default Re: s/pdif, fixed or floating
Such things don't apply to SPDIF.
Old 13th December 2005, 10:23 PM   #3
how so?
Old 13th December 2005, 10:30 PM   #4
SPDIF is only SPDIF while it is travelling between the transmitter and receiver.
Old 13th December 2005, 10:36 PM   #5
nemestra's Avatar
SPDIF unless it is being used to carry a coded format signal such as DTS or AC3 is normally carrying PCM data, for example, from a CD transport to a DAC. PCM data is fixed point.
James
Old 13th December 2005, 10:41 PM   #6
James
But that isn't the raw SPDIF datastream. The point is you cannot do anything with the raw SPDIF datastream other than send it from point A to B.
Old 13th December 2005, 10:43 PM   #7
it's a protocol for data transfer between the transmitter and receiver, I'm just trying to find out if the digital signal it carries in traditional audio applications uses fixed or floating point.
In other words, with a fixed point digital signal you're only using the maximum possible resolution when playing at 0 dB. If you play something at -12 dB you lose 2 bits of resolution, the lower it is the more resolution you lose. With floating point you don't lose any resolution. So, with digital audio, do you lose any resolution when playing something at -x dB?
Old 13th December 2005, 10:44 PM   #8
James
Thanks, that's all I was looking for
How to get a 15V floating supply rtarbell Power Supplies 10 14th February 2007 03:17 PM
S/PDIF Optical to S/PDIF RCA Replacement jdgonko Digital Source 2 11th February 2007 09:35 PM
Floating the heaters YoungFred Tubes / Valves 2 16th September 2006 10:59 AM
s/pdif, fixed or floating sr20dem0n Parts 1 12th December 2005 04:16 PM
Floating voltages eeka chu Solid State 12 29th January 2004 03:57 PM
Page generated in 0.10301 seconds (82.30% PHP - 17.70% MySQL) with 10 queries
