| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | ||
Remco |
#12 | ||
diyAudio Moderator Emeritus
But why do they sound so good then ??? Beter ask Zanden, Audio Note, Marantz and others the same question. Nobody can explain what the reason is they sound so good. Please don't come up that it is commercially good for them, other products create revenue as well. Why would I need arguments anyhow if sound is OK ? To proove your theoretical and / or educational background ? Quote:
It's only audio |
#13 | |||
The usual problem with mulitibit converters is IMD in the I/V conversion. Jocko made a fine circuit that greatly eliminates it be removing the nullor configuration that causes it. Non-os is not a solution, it's lowering the clock to lower jitter problems. That's battling symptoms, not eliminating the problem. Remove the intermodulation mechanism and listen again. It'll sound better. And how inconvenient, it will measure better as well. Quote:
Remco |
#14 | |
Wasn't one of the pretty things of the TDA's and PCM63's that they didn,t suffer from these problems as bad as others do ?
I am very well able to judge my system as well as components thank you. Quote:
I think this discussion looses its character and no valuable info will come out anymore. Besides that the discussion should be continued in a new topic since it really doesn't have anything to do anymore with the Nonoz of Fedde's.
It's only audio |
#15 | |||
Remco |
#16 |
I just don't like the agressiveness you seem to need to "win" your discussion. A discussion IMHO is based on respect.
You win professor, OK ?
It's only audio |
#17 | |
Electrons are yellow and more is better!
Cheap 24/96 DAC with CS43122 NON-OS DAC's are history, why? They will never come back as with tubes. They weren't any good if you compare to modern technology. But if you compared to a cassette tape they sounded splendid! CS8414 + CS???? why don't you test a 8-pin chip from Crystal?
/Per-Anders (my first name) or P-A as my friends call me |
#18 | |
Remco |
#19 |
#20 | |
OK, my last reply:
Try to reverse your own words. Quote:
No, I had hoped for some discussion based on listening facts instead I found yet another technical engineer telling me I just have to explain it, where others did that 5 years ago. You see what I mean ?
It's only audio |
| Chill-amp II page | fedde | Chip Amps | 7 | 22nd February 2006 10:30 PM |
| Nonoz III DAC | fedde | Digital Source | 4 | 17th January 2004 04:57 PM |
| my new web page | Fred Petersen | Swap Meet | 12 | 23rd May 2003 05:49 AM |
| The new Nonoz II DAC page !!! | fedde | Digital Source | 134 | 14th May 2003 06:09 PM |
| Page generated in 0.11810 seconds (84.21% PHP - 15.79% MySQL) with 11 queries |
