Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2005, 06:40 PM   #1
strogg is offline strogg  United States
Default kwak clock troubles
hello,
hopefully this should be straightforward. basically, this is what happens on the oscilloscope test after the build:
with ±12v on the rails...
> 1 amp drawn, and i get a regular sine wave
with ±9v on the rails
just a bit under one amp drawn, and still sine waves on the oscilloscope
the voltage on comparator chip is 4.8v the whole time, and messing with the pot doesn't do anything. and after a while, the power caps will get a bit toasty.... well, makes sense considering it's drawing a ton of power.
*sigh*
so can anyone help? thanks
Old 7th December 2005, 07:41 PM   #2
Banned
Send a message via Yahoo to Elso Kwak
Default Re: kwak clock troubles
HI
1A current are you powering a power amp or a clock? Hell ho!
I guess your caps are the wrong way in or just defective.
The KWAK-CLOCK draws very little current say 10mA + or so and even less in the negative rail. Are ur inductors hot too? I am hot too, and cool[joke]
Pls check for correct output of regulators +/-5V before fitting the comparator.
Old 7th December 2005, 09:17 PM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
Maybe it is oscillating ?
It's only audio
Old 7th December 2005, 09:30 PM   #4
well, the caps are in the right way
i dont' know if the inductors get hot, but i can give it a shot tomorrow (i can't get into the school lab today, and i don't have a ±9v psu on me)
Old 8th December 2005, 06:05 AM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
maybe you wired someting backwards in the power supply (tl431 or transistor)
if you made a pcb, posting the layout here as a picture could help
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
My Kwak Clock 7 zygibajt Digital Source 12 28th November 2010 02:37 PM
49.152 MHz Kwak clock okkyn Digital Source 0 10th July 2007 02:53 AM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
help with Kwak-clock jarthel Digital Source 5 4th May 2002 04:16 PM
Page generated in 0.07307 seconds (78.12% PHP - 21.88% MySQL) with 10 queries
