Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2005, 08:11 AM   #1
Bert72 is offline Bert72  United Kingdom
Default Camb. Aud. CD4SE "no Disc" not spinning
I have a Cambridge Audio CD4 Special Edition. Recently it has been occasionally displaying a "No Disc" message and only recognising some discs. Now it will not recognise anything.
I have taken the lid off and had a look. The disc is being picked up and the laser lifts up 6 or 7 times but the disc will not spin.
Any suggestions as to what the problem could be.
Thanks.
Old 8th December 2005, 11:06 AM   #2
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
Hi Bert72,
Yes it sounds like your Lasers gone (CDM12.1) - the CD4SE is based upon Philips CD7 Digital Servo Chipset - there’s no adjustment, only laser power calibration on the Laser head itself - but from the systems you described - this will not help.
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 8th December 2005, 12:09 PM   #3
I had my CD4SE CD drive changed because of persistent skipping.
Cost £50 (I seem to remember) through Richer Sounds.
/sreten.
Old 10th December 2005, 08:56 PM   #4
Either laser gone for good; initial focus fails so the motor isn't event started, or motor/motor driver problem.
Old 10th December 2005, 10:35 PM   #5
Thanks for all the help!
is there a way to check to see if the motor works?
Old 11th December 2005, 04:14 AM   #6
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Try to the internal picture of it,see what we can do.
Old 13th December 2005, 08:08 PM   #7
I am sorry, i do not understand, could you please clarify.
thanks
Old 13th December 2005, 08:56 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi Bert,
Load a disc and give it a spin gently, with your finger. Disc motors generally go before lasers. Could be a flex cable problem as well.
-Chris
Old 15th December 2005, 02:31 PM   #9
Sorry to sound so stupid, but what exactly should i do? should i take the top off, have it all powered up then spin the disc manually?
Thanks for you help so far!
Old 15th December 2005, 02:59 PM   #10
Fidelity Audio's Avatar
Hi
Take the top off
Power up and watch the disc load.
eject the disc and then re insert it, just as the disc loads spin the disc clockwise. If it spins and you hear some hissing from the laser then your motor or motor circuit it faulty.
If there is no noise the laser has gone.
If the disc wont spin the disc plater may have dropped, just lift slightly with a small screw driver.
But it does look like the laser, the new laser comes part of the transport so you get a new motor and load switch.
Grundig CD 8400 MKII "DISC" ATRAC3 Digital Source 1 4th June 2011 08:36 PM
Sony SCD1 "no disc" problem negus73 Digital Source 15 15th January 2011 03:38 PM
Disc spinning too fast jnewbold Digital Source 8 22nd September 2008 01:02 PM
Noisy spinning disc in Arcam Alpha 7se CDP anb Digital Source 3 10th December 2006 09:22 AM
"No Disc" message Bert72 Digital Source 8 8th December 2005 04:58 PM
Page generated in 0.12454 seconds (80.29% PHP - 19.71% MySQL) with 10 queries
