Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
uneven output on my 206
Old 4th December 2005, 07:30 PM   #1
carlos671 is offline carlos671  United Kingdom
Default uneven output on my 206
HI everyone, not talking about my puegot here, but my meridian. the output from the right speaker is alot weaker when using my cd player. i measured the outputs with my mulimeter and the voltages are lower on the right channel and other source components play evenly so know its not the amp. any suggestions?
Cheers
Old 6th December 2005, 09:31 AM   #2
Extreme_Boky is offline Extreme_Boky  Australia
You are going to need a CRO and circuit diagram. Follow the signal backwards until you get equal levels on both channels. The fault is probably in analog section or muting circuitry. Your CD player may have a discrete analog buffer section. This is good place to start.
Visually check the PCB for any signs of overheating. These are the most likely problem places in any unit.
Check if the power supply lines' levels are the same for both channels. Even better - measure the voltage drop across the resistors placed in series with the power supply lines. Voltage drops should be the same for both channels.
Avoid guessing - you could end up with damaged PCB.
If you are uncertain what to do - give it to a good technician (or one of us on forums close to where you live)
Good luck
Extreme_Boky
Old 6th December 2005, 03:10 PM   #3
Phasenoise is offline Phasenoise  United Kingdom
Phasenoise's Avatar
The 206 is a nice player, meridian gear normaly is pretty reliable. You could give meridian a call or send it back to them for a service.
uneven output on my 206Hide this!Advertise here!
Transformer with uneven ac out geminni Solid State 6 1st February 2008 05:52 AM
Isobarik with uneven signals mashaffer Subwoofers 6 30th May 2006 08:47 PM
Uneven voltage on PS chipco3434 Power Supplies 11 22nd February 2006 02:10 PM
uneven wound 50w OT 2 ideas...? dud_wity Tubes / Valves 13 29th March 2004 12:54 PM
Copyright ©1999-2017 diyAudio
