| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Ok here is the problem. i thought i would use my sound card as a function generator for testing amplifiers and so-on. well life is not that easy.
first of all let me explain the system. i have an EMU 0404 which is my main card for almost everything. the onboard Analog devices soundmax output is plugged into the input of the 0404. thats just because i need the crappy pc mic input for certain things and the 0404 has no mic preamp anyways i looked at a 1khz wave from the EMU with a scope and i got this. (see attachment) this is recorded at 44.1 khz, but it does the same thing at up to 192khz but the ringing is much higher frequency. it doesnt look like normal ringing anyways, it has "reverse ringing" before the transitions as well. i tried other things as well. 1: soundmax output bypassing emu to scope (same ) 2: i thought it might be my cables which are rather long but tried them with the scopes internal square wave reference and it still looked perfect. |
#2 |
just to be sure, i took the output of the soundmax and viewed it on a software scope that was using the EMUs input. now you can see it on the still pic, but (maybe because of the drift between the 2 cards oscillators) the ringing would cycle between out of phase, cancelled out, and in phase.
in case you want to know what the programs are, chainer is free, if you do not want to save presets. it lets you load VST and VSTi plugins directly without a host sequencer. function generator lite is a rather limited but functional function generator. it is free exoscope is a free scope vst plugin anyways, does anyone know how i could fix it? the only way i can think of is to run tests at 192 KHZ and then put just the right capacitor/filter across the output. why are both sound card outputs like that? it is rather annoying now i might have to build a function generator. |
#3 | |
hi neutron7,
Chips on your audio card has FIR filters included, and probably, he has this behaviour. This means that you cannot obtain "clean" pulse from your audio card. If you test audio amplifiers, also good can be wavelets, you can try this This is a four period Hann type wavelets, "video edition" Best regards, boggy |
#4 |
It's normal that a soundcard used as signal generator gives that result, very evident on the square wave. This is because the impulse responses of normal DAC chips used in soundcards (and in all digital devices) are of this kind:
![]() The explanation involves digital signal processing theory and remember also that the soundcards have a limited bandwidth, while a perfect square wave (with all its harmonics) would require infinite (or at least very large) bandwidth. You can observe that a lower frequency square wave generated with your soundcard will be more similar to ideal case, since you have more harmonics in the bandwidth allowed (about half of your sample rate). If you need a perfect square wave you must use a signal generator and not a soundcard. There are chips like the MAX038 that allow to build a signal generator with few components. |
#5 |
a perfect square wave has infinite bandwidth
a soundcard does not have infinite bandwidth... you'll never get a perfect square wave out of ya sndcrd. but if ya bandlimit the sqaure wave before the go to Dig to analog conversion, you'll loose the ringing, but you get rounded edges. |
#6 | |
Hi tchrama,
Especially, pre ringing is relatively rare behaviour, and it's characteristic of FIR filter impulse or step response, for example. Best regards, boggy |
#7 |
thats all very dissapointing news and shows my ignorance digital audio. i will forget this idea and go with the MAX038 suggestion from paologatto.
thanks everyone for the replies. |
#8 |
The ringing is a result of the sharp band limiting itself at 20 kHz. It has nothing to do per se with “digital” or “FIR-filters”. If you mange to build a steep analog filter at 20 kHz you get the same ringing when fed with a square wave. If you want a good square wave, use a simple NE555. But be careful when testing amps with it, most amps cannot handle it and are not designed to handle such steep edges. It is wise to use a 100 kHz (or lower) 1st order low pass to gently limit the bandwidth of the square. Cheers |
#9 |
well i wanted sine and triangle and other waveforms as well as music, i was just using the square wave as an example. thats why i wanted to use the PC sound card and not a simple 555.
anyways that maxim ic looks pretty good. I ordered one allready. |
#10 |
Yes, the Max038 is really nice.. I builded a signal generator with this schematic:
![]() and is very useful. I added also a frequency meter, done with a single PIC, with this schematic: ![]() loading on it this code: http://home.datacomm.ch/str/micro.html (search for "Autoranging frequency meter") The final device is this:
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| Square wave | Prune | Everything Else | 11 | 28th June 2004 06:17 AM |
| Microphone turns triangle wave into square wave? | Circlotron | Analogue Source | 18 | 25th January 2003 06:44 AM |
| Page generated in 0.12534 seconds (80.06% PHP - 19.94% MySQL) with 11 queries |
