Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Soundblaster SPDIF OUT -> 2nd Soundblaster SPDIF IN
Old 29th November 2005, 12:04 PM   #1
bkubi is offline bkubi  Austria
Default Soundblaster SPDIF OUT -> 2nd Soundblaster SPDIF IN
Short Question:
Can I connect SPDIF OUT of one soundblaster to SPDIF IN of a second soundblaster directly via the internal connnectors for the live drive bay?
The drive bay connector pinout can be found here:
http://www.electricstart.de/pic/aud_ext.gif
Long Question:
I own two Soundblaster cards, a new Audigy 2 zs and older Live Value.
They are both in one PC, and both working (I can only install one set of creative drivers, so the Live is with normal windows drivers).
I am running out of recording sources, since mic and line in are already used, and i dont own a live drive bay.
However, there are the connectors for this drive bay, with feature 4 spdif outs, and one spdif input.
I want to create a two-wire cable to connect spdif-out 0 of the sb live card to the spdif in of the audigy, the second wire being ground.
Could this probably work, or did I missunderstand/oversee something important?
Thank you very much for your help.
Greetings from Vienna,
Bernhard
Old 30th November 2005, 04:05 PM   #2
Default It works.
I just tried it:
The soundblaster live has a AUD_EXT Connector
of which I connected the pins 17 (SPdif out 0) and 18 (GND)
to the Audigy 2 zs external port, pins 5(spdif in1 ) and pin 6(GND).
If i tell the sb live to only output digitally, signal gets routed to the spdif in of the audigy.
Additionally I connected pin 25 and pin 35 of the audigy, to simulate a live drive.
Thanks anyway.
Soundblaster SPDIF OUT -> 2nd Soundblaster SPDIF INHide this!Advertise here!
Soundblaster kx driver as a crossover? JaRoD Digital Source 8 10th August 2006 10:41 PM
Soundblaster Extigy willywilly Everything Else 4 21st May 2006 09:00 AM
Newbie Project - Tweaking the SoundBlaster Live! 24-bit J. R. Todd Digital Source 25 10th November 2005 12:28 PM
soundblaster help fire alarm Digital Source 7 21st October 2005 07:27 PM
Soundeasy and Soundblaster Live 5.1 disapointed Multi-Way 0 21st December 2003 05:46 PM
Copyright ©1999-2017 diyAudio
