Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th November 2005, 03:44 PM   #1
Reina is offline Reina  Germany
Thumbs up improving cs8412/14 lf jitter attenuation
hi,
the most impressive result of tuning my parasound d/ac-1600hd was this mod. the sound is clearly more powerful and agile, but low jitter sources still sound better. i would like to encourage all cs8412/14 user to try this mod, if they have not-tuned-clock-devices.
by default only high-frequency jitter is strongly attenuated by the cs8412/14. with the following mod jitter attenuation over the entire audio range is achieved. the settling time increased to round about 1 second, but who cares ? no synch problems with pc and cd-player digital optical out @44.1/48khz and 44.1khz cd-player cinch was flashy.
[schematic attached]
Old 26th November 2005, 03:45 PM   #2
Default d/ac1600hd
n.t.
Old 26th November 2005, 04:16 PM   #3
Banned
Default I can not tell from schema, that
you use separate supplies for analog and digital supplies of CS8412 as well as a decent SPDIF input. Let us know to assess if your advise is worse trying.
If you don't have, separate supplies for VD and VA, doing so will give you a big improvement, especially if you use a decent (low noise) reg.
I have good results with the reg101-5 (for each) as close as possible on the supply pins.
Same accounts for the SPDIF-input.
Henk
Old 26th November 2005, 05:27 PM   #4
Banned
Playing games with the RC vlaues will lower the corner frequency. At the risk of severe overshoot in the response.
IOW.......while it is tuned to a lower frequency, and takes longer to settle, it probably does so because it is underdamped and swings back and forth a few times.
Jocko
Old 26th November 2005, 07:02 PM   #5
I have still no low-jitter clock ready. my best source is a sony cdp-50xaes cd-player and its digital-out sound quality with this mod is improved. maybe the sound quality is slightly decreased when using a tuned low-jitter-clock+hq-out-device. that is still not tested.
even a single 47 uF BG-NX as filter cap is working great and sounds better than the 2 x 0.47 uF BG-NX alone. i tried to lower the r to 330 ohm, which was working for some days without problems also.
greetings.
Old 27th November 2005, 06:13 AM   #6
CheffDeGaar's Avatar
Long ago, Pete Goudreau experimented some values for the filter caps :
Here (7th §)
Also here
And finally here
Worth reading
/Cheff - Falling feels like flying, until you hit the ground
Old 27th November 2005, 04:19 PM   #7
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Monkey-business
Ever heard of the Wildmonkeysects loop-filter?
No monkey-business pls [joke]
http://db.audioasylum.com/cgi/m.mpl?...sects&session=
Old 27th November 2005, 06:35 PM   #8
many thanks for the links, CheffDeGaar and Elso!
but it seems, that nobody tried a electrolytic as filter cap before. that is strange, cause a small electrolytic has less inductance than a big foil capacitor. i came to good results with unpolar black gate nx. but maybe a small rubycon za or even a simple tantalum could make a good job also ?
Old 13th December 2005, 03:54 PM   #9
snowman is offline snowman  Macao
good!
Old 14th December 2005, 02:58 AM   #10
maxlorenz's Avatar
Reina:
I risk non friendly answers by asking this, but i lack knowledge and instruments to test it myself (i only tested "by ear" ) :
I have used the superE-cap configuration ( a pair of non-polar BG's in antiparallel way) with success in A and D power supply (save once that I got audible ringing )
Have you experience with this?
It will only cost you the price of another BG-NX to test it
(I hope Jocko is not around )
Good luck.
M
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
FS: TDA1541 S2, TDA1541A, TDA1543, CS8412, Tent Low Jitter Clock 16.9344 & 45.1584 Zodiac Swap Meet 3 21st February 2008 08:43 AM
10 dB attenuation box june Parts 2 20th July 2004 04:07 AM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
Sample rate convertors and jitter (attenuation) alvaius Digital Source 6 8th April 2002 06:36 PM
Page generated in 0.10996 seconds (78.57% PHP - 21.43% MySQL) with 11 queries
