Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th November 2005, 12:07 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default ST Glass Fiber Optical Output?
I have a transport to play around with (Enlightened Audio Designs) EAD T-1000 that has a ST glass optical output.
What do I need to do to the D/A converter to give it a input to accept this output from the transport, I've heard that this can be very good, is it worth the trouble?
Or just stick to the coax cable conection?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 24th November 2005, 05:09 PM   #2
Banned
Default Well, since you asked.........
If you ask the guys who designed the fiber/laser interface components..........they used to be called AT&T..........they will tell you that fiber is designed to work on links ("spans") where copper gives out as a medium for high-speed data transmission. Which is around 1 km. At spans less than that, too much light is reflected back into the TX laser, and you get a nasty thing called mode hopping. Does horrible things to a digital waveform. Especially if you pick up the fiber cable and move it around!
Yes, it will pass data. No, it won't sound good. Took the clowns at Stereophile a few years to figure that out. Not that we didn't try to tell them......
I think it would be easier to make a coax TX/RX pair than to get your hands on a km or so of fiber, and make a patch cord with it.
Jocko
Old 24th November 2005, 05:18 PM   #3
Banned
Send a message via Yahoo to Elso Kwak
Thumbs up there
There!
Old 24th November 2005, 07:20 PM   #4
georgehifi's Avatar
Right!!
Stick with the coax
Cheers George
Old 24th November 2005, 08:17 PM   #5
KeithC is offline KeithC  United Kingdom
I've been using optical coupling for around 5 years - initially to avoid noise from my PC front-end. Every so often I do a coax comparison, but can't hear any difference.
Current system: Terratec soundcard->DAC1-> Lowther EX3's. 10 metres of glass between the soundcard and the DAC1, the Lowthers fed directly from the DAC1 headphone sockets.
Optical output to Coaxial? Tenson Digital Source 13 18th June 2008 10:53 PM
Indexing gel for AT&T optical glass transport to dac link georgehifi Digital Source 2 4th June 2008 10:46 PM
fiber digital output sma Digital Source 3 9th January 2005 12:53 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 03:57 PM
Optical vs Coaxial output gchrist Digital Source 15 11th February 2004 05:53 AM
Page generated in 0.06341 seconds (83.59% PHP - 16.41% MySQL) with 10 queries
