| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Hi Chicco,
I don't have that one, sorry. What I want you to do is put the probe on the RF test point. Settings are 0.5uS / div (or as high as you can go) and 0.5V/div. use a 10:1 probe. You will see an RF waveform called an "eye pattern". What you normally would do is adjust the focus bias for the highest amplitude and sharpest pattern. Do not move any control very much. The next adjustments can get you into trouble easily. They are tracking offset and E-F balance. Do not touch without the service manual. Send a picture of the RF test point before you do anything. It can be hard to catch. Also, try to measure (DC volts, 2-10 V scale) across a normally 22 R resistor near the RF amp that goes to the flat cable for the pickup head. Calculate the current. Compare to the Iop figure normally printed on the head. I use a laser power meter for quick checks, but they are expensive and I don't know what the expected value is for that head. -Chris |
#13 |
Hi Chris,
I spoke with my friend, he have hand made probe with 50 Ohm cable and termination on both ends of the cable with 50 Ohm resistors. Scope has 1Mohm/30pF input. Is it good at all? In my first inspection I didn’t find adjusting pots, and without schematic I will have hard time to find measuring points and right values. Thursday I will have more time to examine this problematic CDP and I will post new info. Chicco |
#14 |
Hi Chicco,
Sadly, that probe is exactly what you do not want in this application. What is required is a low capacitance 10:1 probe. 10Mohm input impedance (DC). This is the most common probe supplied with an oscilloscope. Common specs are 50 MHz or 100MHz bandwidth for the probe. Really old probes were speced at 10 MHz. To use an oscilloscope for servicing, this is what you need to get a hold of. -Chris |
| Optical Pick Up for CD Player Wholesaler or Manufacturer? | tiefbassuebertr | Digital Source | 14 | 9th January 2012 11:37 AM |
| Sony optical pick-up KSS 273 A | cdun | Digital Source | 6 | 24th January 2010 03:03 PM |
| Marantz CD-7 optical pick-up head | Mike Chan | Digital Source | 2 | 6th January 2008 02:43 PM |
| Marantz CD-7 optical pick-up head | Mike Chan | Parts | 0 | 16th July 2007 05:17 AM |
| Page generated in 0.09860 seconds (74.25% PHP - 25.75% MySQL) with 11 queries |
