Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th November 2005, 07:22 PM   #1
Default Whistling Sound after modding Philips Player
I'm trying to mod my old Philips player running the TDA1541 Chip and did the following:-
a) Added 47n decoupling caps directly to legs 7-13 and 18-24 of the TDA1541
b) Cut off the analog ground track at pin 5 to separate it from the digital ground a run a connection from pin 5 directly to the chassis
c) Also separated digital ground at pin 14 from the rest of the audio circuitry and run a connection directly from the digital ground to to the Chasis.
4) Extensively decouple the audio ICs by soldering 47 caps directly to all the power supply pins.
5) Wrapping the filter chips and TDA1541 with copper foil tape and grounding foil to chassis.
Switched on and sound is very much more detailed but there is a steady soft whistling sound. Could it be oscillation of some sort and what could be the cause.??
ckt
Old 17th November 2005, 07:58 PM   #2
Banned
well sounds like it, have you checked it on a scope?
Old 17th November 2005, 08:47 PM   #3
ash_dac is offline ash_dac  United Kingdom
Whistling sound sounds like my tinnitus
I would pay £ for a cure for that!
Anyway, Gudio Tent knows about this decoupling stuff!
Start here first.
http://www.tentlabs.com/Info/Article...decoupling.pdf
Kind regards,
Ashley.
Old 17th November 2005, 08:58 PM   #4
Francis_Vaughan's Avatar
Default Re: Whistling Sound after modding Philips Player
Bad. Real bad idea. Put them back right now. The idea of separating these grounds like this is simply wrong. This isn't an audio circuit - it is an RF speed one. The grounds do not work like audio. You have cut the ground return lines for very high speed signals and made them return via bits of wire and the chassis. This is going to introduce all sorts of evil problems.
Old 18th November 2005, 01:46 PM   #5
Default Problem solved!!
Thanks Francis. Just reversed the grounding stunt and well, everything's fine but I must say soldering additional decoupling caps directly to the TDA chip does make it sound better. As for digital power supply decoupling, OSCONS are god sent. So much more details and more musical.
If it ain't broken, fix it!
Why Philips CD 723 is a bad base for modding OliverD Digital Source 72 17th February 2009 02:44 PM
WHY Does ROTEL 855 sound so good ;really just a Philips player homemade Digital Source 11 17th November 2006 07:08 PM
Pioneer PD-75 Cd Player whistling allanlew25 Digital Source 5 7th May 2006 12:22 PM
Philips DVP 3005 DVD player modding jkeny Digital Source 1 25th February 2006 08:27 PM
Page generated in 0.08359 seconds (75.62% PHP - 24.38% MySQL) with 10 queries
