| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have bought a second-hand Marantz CD-52MkII that functions very well. I'm interested to know if there is anything I can do to reduce the hardness and brightness. There is very little information about this model on the net. Thanks for reading.
#2 |
Hi ,
Replacing the rectifier diodes with schottkeys would probably be the best place to start . Followed by that replace the power electrolytics with low impedence types and bypass these low value film caps . Even in the KI models the diodes are standard types , I kept the Elna Silmics capacitors that were in mine and just added bypasses . Changing to schottkeys is a cheap mod and you'll notice the difference instantly cheers 316a |
#3 |
Hi 316a. Thanks for the reply. I'm very new to the DIY world. So far, I have only tried replacing the caps in my speaker crossover. Thanks for the suggestion. I'm going to find out about the schottkeys.
#4 |
Beef up the power supply caps with low ESR caps like Panasonic FCs or Rubycon ZLs and bypass them with 0.1uf X7R caps... quite cheap and good at Farnell or at koba.
Remove also the muting transistors .. sound is more open. |
#5 | |
Also line the inside of the top cover with Dynamat , use any offcuts to damp the transport . Other simple mods for Marantz players are to add a mains filter and change the output jacks . The output jacks on my CD-63 KI had horrible dry joints upon inspection and only were gold plated on the ground connection ![]() cheers 316a |
#6 | |
#7 | |
Hi Jomar. Thanks for the response. Farnell and Koba are selling online only? Do you know where can I get the Schottkey diodes and the low ESR caps you mentioned in Singapore? So far I have only tried replacing the crossover caps in my speaker to Solen. I got them from a shop almost right next to the Martin at Burlington Square. |
#8 |
I have followed the instruction on this Web page to remove the muting transistors.
http://margo.student.utwente.nl/klaas/audio_cd.htm There were 4 of them at the bottom of the PCB. It is so small I took a while to find them. It is very hard to remove them without destroying them. I tried unsoldering but they remained tightly coupled to the PCB. In the end, they were pryed and removed in small pieces. I did notice the change in sound immediately. There were more clarity. This mod coupled with the replaced caps in my Mission M71 bookshelf makes the sound much less harsh, more dynamic, and detailed. It is really amazing how far we can go with so little effort and money. I have yet to find the rectifier diodes on my CD player. Perhaps it is hidden under the transport? I think changing the rectifier diodes will be my project for this weekend. Thanks again for all the help. |
#9 |
Do you have any pictures of the inside of your player? They'd help in finding the rectifier diodes. I'm also replacing mine (in a cd6000 ki) with schottky (there's no 'e' in schottky) types this weekend. Good luck!
#10 |
mr Hacker has a busy weekend ahead
Just playing JMJ LOUD on my new 250. My Arcam has schottky's so far im not convinced, might be the wrong types (just what I had handy) but its early days and I changed caps at the same time. Might try to get hold of some 11dq10 to try, is that what you are using Hacker ? |
| Marantz Cd 67 | bull041161 | Digital Source | 4 | 13th April 2009 09:39 PM |
| Effects of Solid Wood Hardness on Sound | konut | Multi-Way | 5 | 8th September 2007 04:31 AM |
| Fix my Marantz | richie00boy | Digital Source | 23 | 19th April 2006 12:14 PM |
| Right speakers for Marantz PM8000 + Marantz CD67-OSE? | betto80 | Multi-Way | 2 | 24th May 2005 03:21 PM |
| Link Between Marantz CD12 and Marantz CD99 | Mesh | Digital Source | 16 | 7th November 2003 06:08 PM |
| Page generated in 0.10763 seconds (80.81% PHP - 19.19% MySQL) with 10 queries |
