Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th November 2005, 03:37 PM   #1
Paco is offline Paco  Spain
Default Non working DAC
Hi all,
I have a CEC DX51 dac that a friend gave me because it doesn't work. I have no idea of digital electronics. The dac looks perfect, I connect it and there aren't any problem. It's a modular system and the DAC section uses four BB PCM1704 chips. When I play music trought it I can only hear some kind of white noise. Any ideas?
Best regards,
Paco
Old 9th November 2005, 01:26 AM   #2
What chip lineup does it use i.e SPDIF receiver, digital filter etc ?
Old 9th November 2005, 02:01 AM   #3
Check if the input SPDIF connectors' middle pin(s) are soldered to the PCB. Is there an LED for "signal lock"? Is it on when you press play on your CD mechanism / player?
Extreme_Boky
Old 9th November 2005, 06:23 AM   #4
Banned
Send a message via Yahoo to Elso Kwak
Red face Re: Non working DAC
Originally posted by Paco
Hi all,
Best regards,
Paco
No idea of digital electronics and trying to repair? Hey ho!
First check all powersupplies for correct voltages and inputconnector for bad contact especially when soldered directly to the PCB. Have a scope ? Odd question, yes??
Old 9th November 2005, 07:19 AM   #5
Hi all,
Thanks for your replies.
More info: I’ve used the coaxial and the “superlink” (a CEC proprietary connection that uses a RS232 cable) and none of them work make the DAC work correctly. The noise is different when using one or the other conection (there’s more noise with the coaxial) but no music at all.
The decoder module uses CS8414, the digital filter uses BB DF1704E and the DAC uses 4 BB PCM1704. I can send photos if it could help.
Hi Extreme_Boky, at a first glance, it looks ok. When I play music the led “play” on the DAC turns on but I only have noise at the output.
Hi Elso. I just wanted to see if I could see something wrong and I couldn’t. If I can have an idea of where’s the problem from someone who knows about digital electronic there’s a possibility to repair it. If I can’t solve the problem I’ll order a DAC and use the housing and the PSU’s components to build a new DAC.
I’ll do it.
I don’t have a scope but I have an ATB Precision measurement equipment (that I use to design loudspeakers). I know that it has a 2-channel Oscilloscope with FFT Analyser and 100khz of max sampling rate, but I have no idea of what should I measure in a DAC, so this function is mainly useless for me right now.
Thanks for your help!
Paco
Old 9th November 2005, 02:06 PM   #6
If you haven't already done so, download the datasheets for the CS8414, DF1704 and the PCM1704. Having done that you can then check to see that all the voltages are present and correct.
If all the voltages are correct the next step would be to test the CS8414. With the SPDIF disconnected test pin25.It should be high. When you reconnect the SPDIF pin25 should go low indicating signal lock
Old 16th November 2005, 07:11 PM   #7
Hi rfbrw,
Thanks for the info. I'm overcrowded with work at the moment (weekends included) so it's difficult to me to make tests. I've found replacements for the DAC board in ebay very cheap and I've ordered one of them to replace the existing. I think that the problem is here, but I'll be sure shortly.
Best regards,
Paco
Old 10th September 2011, 01:58 PM   #8
Hi all,
I have problem with CEC DX51 too. Theres is no sound in the right channel, left is full working. Maybe some of you have any ideas, or can help me to find technical manual?
Thank you!
Amp non working covik Solid State 0 12th November 2006 08:12 PM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
sub amp not working felzi Chip Amps 0 28th July 2005 05:29 AM
p3a not working, help! benmanf Solid State 9 27th May 2005 01:02 PM
Page generated in 0.10686 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
