DSD ADCs and DACs - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th October 2002, 03:23 AM   #1
Brett's Avatar
Default DSD ADCs and DACs
Hi all,
Does anyone know if any chip manufacturer makes DSD type ADCs? I'm looking at implementing a multichannel delay for my horns and, well, generally I find PCM sucks. There won't be any processing going on, just a simple delay that I can tap at a number of points for the varying length horns.
Also any opinions are welcome on the various flavours of DACs out there that support DSD.
Cheers
Old 11th October 2002, 09:55 AM   #2
kiwi_abroad's Avatar
Burr Brown makes a few DSD capable DAC's that also accept PCM. If you look at their data sheets, they simply have two front end recievers, one for the DSD, and one for the PCM. After that the signal goes to the same oversampling filter, and the same DAC output, so in theory they will sound exactly the same, given the same input data.
Specifically I'm talking about the DSD1608, 8 channel DAC. I got a couple on sample, and have yet to put it into a working project. I have to work myself up to figuring how to solder a 52 pin SMD chip with 0.65mm pin spacing.
Cheers, Adrian
Old 13th October 2002, 02:45 PM   #3
weissi is offline weissi  Europe
weissi's Avatar
Burr Brown PCM1738!
regards / servus
Old 13th October 2002, 02:54 PM   #4
MWP is offline MWP  Australia
Sorry to kinda skew off the topic here, but ive also got a couple of those DSD1608s.
Anyone have inventive ways of easily using these 0.65mm pinned ICs in DIY circuits?
Old 13th October 2002, 03:55 PM   #5
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Solder them to the board.
Old 14th October 2002, 06:09 AM   #6
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
check out the wiki...
http://www.diyaudio.com/wiki/index.p...ntDeviceRework
Specifically, there's a relevant link at the very bottom of the page... (the one to elm-chan.org)
I know the page looks a bit boring, but there are helpful pictures behind most of the links. Maybe some day they'll be displayed in the actual article as I intended...
Uhh.. the contents of that link might blow your mind at first, but I hope you'll eventually start to see how it's done and that it's actually not as hard as it looks. I think it's mostly a matter of getting your head around the idea of working with such tiny things.
I have some additional comments to post to the wiki, specifically with respect to that link and my experiences with the technique, so I'll try and do that soon. I also need to post a few photos and comments for the other SMD construction techniques.
- Chad.
Old 14th October 2002, 07:31 AM   #7
hifiZen's Avatar
ok, i just posted a whole bunch of new stuff in the wiki page under DIY construction techniques for SMD. check it out...
- Chad.
Old 14th October 2002, 07:46 AM   #8
hifiZen's Avatar
just a peek at elm-chan.org:
- Chad.
Old 14th October 2002, 08:59 AM   #9
You make that look almost too easy, I'm almost looking forward to getting stuck in...
I'd love to see a photo of your "House-O-Cards" construction method
Thanks, Adrian
Are there any DIP 24/96 or 24/192 ADCs and I2P to FireWire Codecs? BoilermakerFan Digital Source 0 21st July 2008 08:27 PM
FS: ADCs - AKM AK5392-VS bruinbear714 Swap Meet 0 1st July 2005 06:56 AM
Using ADCs the correct way sync40 Digital Source 2 19th March 2005 06:45 PM
ADAT recorder ADCs... Tieftoener Digital Source 17 22nd September 2003 07:31 PM
Audiophile ADCs? MurrayP Digital Source 12 17th December 2002 06:21 AM
Copyright 1999-2017 diyAudio
