Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th February 2006, 08:40 PM   #41
Originally posted by Alexandre
Interesting thread! I am looking forward to see your PLL solution.
I need to implement a PLL to get 128fs from 64fs, to clock a spdif TX (Crystal CS8402, if I can get it). Do you know of any reference designs or application notes of 4046/9046 ?
BTW, my RME Digi96 soundcard has a 4046 in it, so this must be a good chip.
Best regards,
Alexandre
What are you trying to connect the CS8402 to? Perhaps I can help, I have some experience with the CS8402.
Old 13th February 2006, 10:02 PM   #42
KimBOlesen's Avatar
Send a message via MSN to KimBOlesen
Why not use the latest CS8406 chip?
Best regards
Kim Olesen
Old 14th February 2006, 07:29 AM   #43
Hi, thanks for the replies! Let me explain what I´m up to.
I am planning a NOS DAC with TDA1541A. The DAC will be clock master and will put out a spdif signal to slave my soundcard (RME Digi96). I will use toslink optical I/O. The DAC will be strictly 44.1 KHz.
I would like to use CS8402 for simplicity and DIP package. But I don´t have it and it´s hard to get, so I may go for newer chips. I will try to describe my clocking ideas below.
CS8402 will be in format 0, so only MCK at 128fs is needed to transmit. Transmitted data will probably be all zeros. The CS8412 will be in format 3 (fsync and sck are inputs). At this point, there are different ways to go:
1)Use XO at 128*fs (MCK for CS8402). Divide to get 64*fs (sck) and 1*fs (fsync). Feed sck and fsync to CS8412 and DAC at once.
2)Use XO at 64*fs. Feed directly to sck input of CS8412 and DAC, for lowest jitter. Multiply by 2 to get 128fs for MCK of spdif TX. Fsync derived from the 64*fs.
3)Use a higher XO frequency like 256*fs, divide to get all the other frequencies (MCK, SCK, FSYNC). Synchronously reclock all 3 signals entering the dac chip (SCK, FSYNC, SDATA). The flip-flops in this case would be clocked directly from XO.
Option (1) is what I´ll try first, using synchronous counters like HC163. Option (2) is appealing to me because of clocking DAC directly from XO, and also because I´ll learn about PLLs. Option (3) is also interesting...
I am open to all ideas and suggestions. What you think would be best?
Alexandre
PS: Somebody has a spare or two of Crystal CS8402 spdif transmitter???
Blu ray - adding a digital in Graeme Hancock Digital Source 0 25th July 2008 11:50 PM
Adding digital out to a CD player with only PCM! Destroyer OS. Parts 0 4th June 2006 09:51 PM
Adding Digital Inputs ?! Blue_Max Digital Source 3 25th January 2005 07:12 PM
Adding Digital Radio To Clio 182 mcyates Digital Source 0 6th September 2004 11:09 AM
Page generated in 0.08028 seconds (68.00% PHP - 32.00% MySQL) with 11 queries
