| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm trying to replace the transport mechanism in ML31.5 . Originally there is CD 12 Industrial mechanism in that transport and 33.86 clock replacing the crystal on Philips board. There is another clock for reclocking the output.
Yesterday, I swapped mechanisms (using CD-Pro2 with 33.86 clock connected in a same way), but the transport has problem with reading CDs and there is an error message. Anybody knows if direct replacement is possible, or do I need to take care of software/clock as well? I will be surely contacting Madrigal as well, but from what I heard so far, dealing with them is not particularly easy.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2 |
in order to have the cd-pro2 work at 33.8688mhz, you have to put the SELPLL pin of the saa to the ground. There is a small pad near the selpll pin and it's tied to +3.3v by a 10k resistor, so you can put it to ground directly
#3 |
Thanks for the info. I checked how it's done with CDM12 IND, and SELPLL pin on SAA7376 is not connected to ground, so I'm not sure if I should be proceeding with that. I contacted Madrigal and I'm waiting for their instructions.
In a meantime here's how the magnet for the clamp is attached.
#4 |
I must admit that I'm impressed with a support I'm receiving from Madrigal. I made a phone call today, and within an hour an almost complete schematic of LM31.5 transport was sent to me, together with detailed instructions for mechanism installation and modification. The actual mod says:
"CHANGES NEEDED TO USE CDM PRO2 IN NO.31.5 Remove df80 and attach a 28 or 30 awg jumper from tp2 to df80-3 on the SVI board." which basically means that 33 Mhz clock is disconnected and another clock signal is supplied directly from DSP. I sent them additional e-mail question, and the automated reply was generated before the end of a day: "We have received your email on the above named subject. Thank you for contacting us. We are addressing your inquiry and will respond as soon as possible. Best regards from your HSG Customer Service Team! P.S. This is an auto-reply. Please do not respond to this email; this email was sent from a SEND-ONLY address and is unable to receive messages. Also, please avoid contacting us via email on this subject again, as it will slow down our ability to respond. If you have an urgent problem and need more immediate assistance, please feel free to contact us via telephone at 781-280-0300 (Monday through Friday, 9:00 AM - 5:00 PM ET)."
| supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 | smartech | Vendor's Bazaar | 1 | 10th April 2011 11:02 AM |
| Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. | Julien_M | Swap Meet | 5 | 25th January 2009 12:03 AM |
| One clock for CDM12 Pro2 and Nos Dac TDA1545 | gochtoni_toni | Digital Line Level | 28 | 28th November 2007 12:31 AM |
| PCM1794 DAC and CD pro2 clock | galouche | Digital Source | 0 | 9th July 2007 11:00 PM |
| External clock to CD-PRO2 | kenev | Digital Source | 59 | 5th October 2005 09:58 PM |
| Page generated in 0.07944 seconds (74.87% PHP - 25.13% MySQL) with 11 queries |
