| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
The problem is that when i start CD Player , after 15 till 30 minutes , he starts with pops and crackles. This is exactly the same situation like i shake CD player. How do I repair that problem? If it helps: the player is equipped with CDM4 SAA7310/TDA1543
Thank You very much Best reggards Niki |
#2 |
Niki,
Here are some possibilities: Check if the SAA7220 ( if used) is temperature sensitive. Check C2572 for bad solderings. You will probably need the manual. Check for a worm out pivot by the ball of the clamper. Pivot: 4822 466 92257 Ball: 4822 520 40177 Don’t forget to grease the ball after replacement Recommended grease: PG65: 4822 690 20139 /Hugo
#3 |
Ok, SAA7220 is used, i added heatsink to the body of SAA7220...
These changes i made to PCB: resolder all condensers against bad solderings and replace condensers around and below optics, replace transistor BC338 below optics, just in case. I don't have manual and i can find on hole internet i'm very sad about this...i can not find C2572 , what kind of C is it and what place on PCB? For Pivot, ball and grease i can not shop from internet from Bulgaria and i don't have credit card... tctctc... tragedy... The problem still exist!! When CDPlayer works some time, 15-40 mins, then sound starts clicks and pops... help? |
#4 |
Try to increase a laser bias current, be very carefull , take a small steps. Trimmer pot is somewhere on PCB near connector of flat ribbon cable of pickup assembly.
If this works , it is time you start thinking about buying a new laser (the whole transport). |
| Philips 22AH578 - strange semiconductors | audiomatic | Solid State | 18 | 14th August 2011 10:54 AM |
| Service Manual Philips CD480 & 380 | rbroer | Digital Source | 24 | 11th May 2009 09:53 AM |
| strange hum problem | zeus_threat | Solid State | 8 | 18th December 2007 03:55 PM |
| philips cd104 strange problem | dm2a | Digital Source | 0 | 21st August 2007 08:08 PM |
| Strange problem with Philips CD753... | martipie | Digital Source | 1 | 4th April 2006 12:13 PM |
| Page generated in 0.08147 seconds (81.94% PHP - 18.06% MySQL) with 10 queries |
