Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd October 2005, 03:12 PM   #1
Send a message via ICQ to bezobraznia
Default Question about SONY CDP-470 CD player upgrade
Hello,
I've purchase it used SONY CDP-470 CD player
The mechanic are ok, sound too, but i want somerhing more from that CD Player...
Any ideas for upgrade of digital or analog part?
When i look at pcb i can't see any opamps for replace!?
Thank You in advance!
Best Reggards
Niki
WELCOME TO THE WORLD OF HIFI
SE + FULLRANGE RULEZ!
Old 22nd October 2005, 09:34 PM   #2
Default Re: Question about SONY CDP-470 CD player upgrade
Perhaps it belongs in the same series as my CDP970. Look at the two large chips close to the output: are they PCM56?
If they are then it's probably very alike.
You should get yourself a service manual before you do any mods.
Carlos
Old 22nd October 2005, 10:20 PM   #3
Thank You Carlos,
The chips in CDP-470 are:
bigest: OKI C6458-38
too big:
Sony CXA1081
Sony CXA1082B
and smalest:
CXA1291 (2 pieces, close to optics)
M5294P and M5204P are close to output
Sony CXD2550
Sony CXD1161
M5231 is smales 5 pins vertical montage
Except chips there are 5 trim-pots with this signs:
T BAL
F BIAS
F GAIN
T GAIN
VCO
, but there are no any PCM's huh...
I really hope someone have service manual for Sony CDP-470?
Old 22nd October 2005, 11:23 PM   #4
Maybe you can't get too far with this player. If I am not wrong those chips are the analog stages.
The thing to do might be to improve the chips and the parts around them. But I think the ICs are vertical types, which make the swapping not too much straightforward. But you can get adaptors that might let you do that.
You can also improve the power supply, with better caps and better regulators. but I would start with the analog stage.
AFTER you change the ICs, perhaps using low-offset types, you may consider eliminating the output cap. But not until you have an output of just a few millivolts there.
Carlos
Old 22nd October 2005, 11:43 PM   #5
Hm, i think that reffering to this datasheet M5294P are not amplifier but Reset IC's, i suppose that M5204P was similar...
M5294P Datasheet
and yes, i will start with analog part
I'm still looking for shematic of CDP-470
Old 24th October 2005, 07:42 AM   #6
Hi bezobrazniq,
"Kak e w Ruse "
So, as I wrote in dir.bg, after the CXD 2550 digital filter some DAC should be there! What is after it?
If you find a multibit DACs there, probably you can improve the player a lot. But the analog upgrade may give less results than the PSU and Clock upgrades.
Go on and try, and if you come to Sofia I can show you how an old Sony can sound, for you to have a starting point. But, mine is multibit one - PCM56P x 2
I'm still searching for the perfect housing player for my 2 AD1862s....
Old 24th October 2005, 10:25 AM   #7
Default news
There is some new elements "arived" after look at the bottom of PCB:
Sony CXD1125 (with sign on PCB sit nex to chip- DSP) and Sanyo LC9600P (with sign- RAM). They are close to Sony CXD2550.
There is signs below parts, on the other side of PCB:
below Sony CXA1081 - RF
below Sony CXA1082B - SSP
below Sony CXD2550 - DF
below Sony CXD1161 - D/A
and below, between CXD1161 and M5204P there is sign: AMP
Analog out come from M5204P through resistors ot RCA's.
The sign of the clock is:
D169D9
908-22
Old 24th October 2005, 11:35 AM   #8
I'm waiting for you to filter the DC supplies and see the effect. Then you may proceed with external Bessel filter after the DAC - see if you have a couple outputs for each channel to the M5204 chip - so you should have 4 signal lines. then you can install differential input /bessel/ filter - for instance the one from AD1852 or AD1853 datasheet, with you fashionable OPamps or discrettes if you want
Old 9th October 2008, 01:56 PM   #9
Default SONY CDP-470 CD player
I am the original owner of a SONY CDP-470 Compact Disc Player. Servo Stabilizer Circuit/Digital De-Emphasis. Recently a problem has occurried. The CD Drawer Compartment tray does not open or close when the open close button is pressed. Their is a clunking noise from the rear of the drawer.. Any body have any suggestions for me???
Old 9th October 2008, 02:40 PM   #10
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I'm not familiar with that model but maybe needs a new drive belt for the drawer drive.
Schematics SONY CDP-791 for upgrade CJAVIER Digital Source 4 10th August 2010 10:37 AM
Sony CDP XA 50 ES upgrade ability.... noogie Digital Source 44 28th June 2009 12:38 PM
Sony speaker upgrade question. type Multi-Way 3 27th February 2006 05:55 PM
Cheap CD-DVD-MP3 player upgrade? Kees Digital Source 1 26th September 2003 07:05 PM
cd player upgrade shallenn Digital Source 4 3rd September 2002 10:49 PM
Page generated in 0.10551 seconds (82.03% PHP - 17.97% MySQL) with 10 queries
