| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
A nice portable multimedia player I'd like to buy has this audio output: "Digital Coaxial (DTS pass-Through only)".
What kind of digital output is this? Can It be connected to the SP/DIF input of a DAC? Best regards. Paul |
#2 |
AFAIK, it means that it would give you bit accurate output and it can't decode DTS. You should be able to use this player as source for DAC
#3 |
Thank you.
Paul |
#4 | |
The digital output can also be used to output 2-channel PCM (this is what your DAC wants), or a Dolby Digital data stream. What comes out of the digital output depends on: 1) what type of soundtrack is being played, and 2) the setup of the player. |
#5 | |
My message consists of 3 parts, could you please indicate which part of it is wrong: [ ] it would give bit accurate output [ ] it can't decode DTS [ ] it can be used as source for DAC Thanks, Viktor |
#6 |
I have in mind to play vaw files, obtained from a CD ripping tool, with the portable player. I want to bypass the internal DAC and connect the digital output to the DAC of my hifi gear (better sound expected).
Is that "DTS pass-through digtal output" suitable for this job? Best regards. Paul |
#7 | |
| digital crossover w/digital output? | ezkcdude | Multi-Way | 30 | 3rd August 2006 02:01 AM |
| Get digital signal from an old CD-Rom without digital output | genome | Digital Source | 5 | 4th February 2004 12:54 AM |
| need for simple all pass digital delay | mr_ro_co | Digital Source | 6 | 20th January 2004 11:04 PM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 01:57 PM |
| Page generated in 0.09658 seconds (76.73% PHP - 23.27% MySQL) with 10 queries |
