Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th October 2005, 09:14 PM   #1
stvncar is offline stvncar  United States
Default problem with an arcam cd73t
help--i did an opamp upgrade on my arcam 73t and in the process lost the right channel completely. i replaced both op amps with the bb627's, and the one in between with an ad8066. i originally thought that the center one might be the problem, but that turned out to be ok. i had to desolder from the top of the board and did touch one of the resistors with the soldering iron accidentally, but i don't think it was enough to fry it. when switching the op amps, the same channel is out and the other one works fine. i tried desoldering and resoldering in case that was the problem, but to no avail. i'm unsure where to go next with this. any advice would be greatly appreciated.
steve
Old 18th October 2005, 11:12 PM   #2
Steve,
Do you have the schematics ?
Jon
Old 19th October 2005, 12:47 PM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Try the original op amp in the faulty channel. Always a good idea with these is to use an IC socket so you can swap and change easily and also stops and over heating of the op amp by soldering.
Soldering the op amp to the PCB is the recommended method but have had no problems using IC sockets.
Arcam Alpha 9 problem Colin151 Solid State 14 20th January 2011 10:54 PM
Problem with Arcam Alpha 7 CDP Tripmaster Digital Source 1 9th April 2009 08:04 PM
Arcam CD72 CD player problem gg41r Solid State 4 14th February 2009 12:43 AM
Arcam Delta 290 Sound Problem phil_79 Solid State 6 10th August 2008 10:57 AM
Arcam Alpha 8R problem goodlife Solid State 2 7th July 2006 09:16 PM
Page generated in 0.07231 seconds (72.27% PHP - 27.73% MySQL) with 10 queries
