| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
I want to transfer a huge LP collection to CD-R for occasional listening, ...in my office, car etc. I bought external M-Audio Audiophile USB ADC/DAC It can record up to 24bit/96kHz My TT rig is: Thorens TD-126 MkI turntable, SME 3009 S2imp arm, Shure V15VxMR cartridge, Graham Slee Gram Amp 2 SE phono preamp, My SME was rewired with Van den Hul MCS - 150 M cable. Cable from tone arm to preamp is Van den Hul D - 502 HYBRID. Shure V15VxMR has this microridge stylus, which is great for archiving old LPs - much less distortion from worn out grooves. The downside is that the treble is rolled off and the sound is too warm for my taste. (yes, I played a lot with cables and capacitance, but this just seem to be the character of this cartridge) Using test LP sweep tones, I created a custom graphic EQ preset for Adobe Audition 1.5 (CoolEdit originally before Adobe bought it). Now I get ruler flat frequency response from my cartridge/cable/preamp combination and the sound is much crisper now :-) The big question is: do I record at 24bit/96kHz, apply the graphic EQ and then downsample to 16bit/44.1kHz? At first I thought that this is a good idea. But then I started reading numerous web pages dedicated to downsampling... My brain got swollen from all this dithering, triangular noise shaping, custom curves, bit mapping, etc. I came to conclusion that I might get some distortion, additional noise, lowered dynamic, digital artefacts, etc. when I downsample. On the other hand, 24bit has much more information to work with... I only plan to use the graphic EQ with the adjustments no bigger than +3.8 dB. Nothing drastic. Do I get better sound by applying moderate EQ in 16bit/44.1kHz, or doing it in 24bit/96kHz (or better a 2x multiple of 44.1kHz) and then downsampling to 16bit/44.1kHz If downsampling is better, what settings would you recommend for Audition/CoolEdit? Thanks a lot, Aleksandar |
#2 |
Downsampling should always be the last stage in the process as any digital eq is subject to rounding errors which will introduce distortion - this will be far less noticable at 24bit than 16bit.
#3 | |
So you are saying that distortion introduced by downsampling from 24 to 16 bit is less, compared to applying moderate EQ in 16bit? |
#4 |
No, Im saying that if you are recording in 24bit then you should eq 24bit, just because you can.
24 bit will always capture your input more accurately, and you sound like the sort of person who would notice the difference |
#5 |
OK, I'm not sure if you understand my dillema.
I won't use 24bit only because I can. I know that 24bit contains more information and that theoretically I should do all editing in 24bit. But I'm not staying in 24bit, because I will burn 16bit CDs. Downsampling from 24bit to 16 bit seems to be a very complex thing and it can introduce distortion and many artefacts on its own. Since my final output is 16bit CD, I'm wondering which is going to do more harm to my music: a) EQ in 24bit followed by downsampling to 16bit, b) or EQ in 16bit without resampling. |
#6 |
Why not just leave it at 24/96 and burn them as audio DVDs, since DVD-R blanks are now cheaper than CDR. 16/44 is sinking into the tar pits of history.
See this page: http://www.eximius.nl/dvdaudio.php |
#7 | |
I don't have a DVD-A player. My Panasonic DVD player has 24/192 DAC, but its analogue section is crap and it sounds awful compared to my Rotel RCD1072 CD player. Also I can play my CDs anywhere, not so with DVD-A
#8 | ||
Some DSPs maintain the audio samples at a very high resolution internally: 32 bits is very common, and 48 bits is used as well. At the final output, the audio is decimated to the required number of bits. Since most EQ is done using IIR filters, maintaining high precision is extremely important; rounding errors can lead to unstable filters since the output becomes part of the input. 16 bits is generally considered to be insufficient for IIR filters in hi-fi audio. You can bet that even if CoolEdit/Audition is using 16 bit input and output files, it is maintaining at least 24 significant bits during processing, decimating back to 16 bits after processing (and hopefully only when saving the file). |
#9 |
Sorry, I didn't make myself clear enough
Recording and eq'ing at 24bit 96k then resampling ( dithering) down to 16bit 44.1k will sound better ( in theory, depending on your ears and equipment ) than recording and eq'ing at 16bit. There will be a loss of quality going from 24bit to 16bit as you are discarding data I would agree that you would be better using dvd-r and making audio dvd's, but that might require some new equipment to play back on. I am not an expert on dithering algorithms, so , if it were me I would stick to the default settings in whatever program I were using - that whole area is very complicated....but its better to have started with more accurate (24bit) representation of the audio, especially with dynamic material. Its easy to get bogged down in sound conversion techniques ,but the differences are normally marginal and far outweighed by the fact that your data(music) is more accurate to begin with. I would try recording 10 seconds of dynamic audio at 24 bit and the same material in 16bit - dither one down and see if you can hear the difference - set it up so you can do an easy a-b comparison - thats a good way of auditioning different dithering techniques too If you keep the original raw 24 bit files archived, it will make it easier to redo the cd's if you find a dithering technique that works better for you, rather than starting the whole process again Hope that helps... |
#10 |
96 to 44.1 math works fine, finding an implementation you can be confident in is more difficult
you may be able to record @ 88.2 Ks/s 24bits which renders the decimation trivial, you still need to find competent bandlimiting filter and rounding/dither code surely these are available as plugins somewhere maybe audioasylum's PC Audio forum could help |
| Here is another "new" CD format = 24bit to 16bit | FastEddy | Music | 31 | 15th September 2007 11:24 PM |
| A/D 24bit/96khz convertor help | sunny | Digital Source | 1 | 16th October 2006 01:35 PM |
| 16bit software with 24bit soundcard for measureing | mikee55 | Subwoofers | 3 | 12th January 2006 10:57 PM |
| USB to 24bit/96KHz | edpgc | Digital Source | 8 | 21st November 2004 02:40 PM |
| a/d converter 24bit 96khz s/pdif recording | JBL | Digital Source | 1 | 11th January 2003 12:58 AM |
| Page generated in 0.14911 seconds (78.48% PHP - 21.52% MySQL) with 10 queries |
