Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th October 2005, 08:45 AM   #1
Question help with CLD-V2800 digital, I2S, EIAJ?
I am modifying a Pioneer CLD-V2800 LD/CD player and trying to hook up my NONOS dac to it...
my dac uses TDA1543's and i was using it with a NEC Cd player which uses EIAJ so i have a little board that does EIAJ to I2S which is what the 1543's use...
anyhow... the player uses a TC9276P DAC, when i steal LRCK, BCK, and DATA (along with ground) and hook them up to the dac's I2S input, i get horrible noise, similar to when i hooked up the NEC straight to the I2S input... so ok it must be EIAJ right? well i hook that up and the right channel sounds fine and the left channel sounds horribly distorted and at a very high level/clipping etc...
i know the DAC is fine cause when i hook it back up to the NEC (using the EIAJ input) life is good again, so what kind of data is this dac recieving and is there any hope in getting my dac to work with this player?
this is the pdf for the dac if that helps any
http://flecom.fragmachines.com/TC9276.pdf
thanks
Eiaj input for AD1865 guglielmope Digital Source 2 29th April 2008 08:18 PM
Is the PCM-61 Dac are I2S or EIAJ data input ? gaetan8888 Digital Source 2 7th August 2007 05:08 PM
EIAJ to SPDIF??? stefaca Digital Source 1 4th September 2006 01:37 PM
I2S and EIAJ johnthedoctor Digital Source 0 21st July 2006 06:13 PM
Can you find the EIAJ? (Sony D-2) velmeran42 Digital Source 1 23rd August 2005 04:43 AM
Page generated in 0.06845 seconds (69.56% PHP - 30.44% MySQL) with 10 queries
