Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th October 2005, 04:52 PM   #1
ronardi is offline ronardi  Hong Kong
Lightbulb stack up dac chips
I saw some people stacking up dac chips in their dac, what is it for? will it yield better sound? I saw some stacked up two and some up to four chips per channel, is it really uesful or just a waste of money?
btw, if dac chips is stackable, how about opamps or else? what it would turn out?
Andrew Chan
Old 13th October 2005, 06:39 PM   #2
dddac is offline dddac  Germany
On my site you can read some background. I did 8 chips stacking to decrease bit error. Works very well. Some DIY did 16 chips and sound improved. I have a prototype with 24 dacs which runs even better and I am now stacking 60 chips.
regards
doede
www.dddac.de
Happy listening and building
Old 13th October 2005, 06:51 PM   #3
analog_sa's Avatar
It is possible to parallel nearly anything with due care. Objective parameters (bit error, noise, max current) usually improve.
Old 14th October 2005, 01:06 AM   #4
You are right analog_sa. Nice thinking.
I have paralleled OP275 with very good results. It is one of the mods that really improve "everything". In particular if you are driving difficult interconnects. Definition, amount of details, 2D and 3D all got better.
One half was used as line out buffer, the other half as a buffer to the headphone OP. Headphone circuitry was disabled anyway. I used both halves of OP275 in parallel to drive line out.
Give it a go - you have already done the thinking part!
I have also modified one of the Audio Note DAC's - i think it was DAC 2. It is a nice sounding DAC, hampered with wobbly valve output stage, unfortunately. Beside other things, I paralleled PCM63 with very good results
So, paralleling does work.
Extreme_Boky
Old 14th October 2005, 11:43 AM   #5
regards
doede
Are you going to sell PCBs for this new DAC Doede?
Old 14th October 2005, 12:35 PM   #6
yes I will, expecting end of the year....
regards
doede
www.dddac.de
Old 15th October 2005, 01:10 AM   #7
maxlorenz's Avatar
Default Hi Doede:
And you will certainly need beta-testers like...
I did the 16*tower mod in Doede's amazing DAC and what stroke me (appart "more of everything") was the denser musical texture, like an improved "continuity", analog continuity to the sound.
Mauricio
Old 20th October 2005, 09:58 AM   #8
It was DAC 3, actually:
Extreme_Boky
Old 20th October 2005, 02:13 PM   #9
fumihiko's Avatar
can not connect pin1,3,4,23,24,25 upper chip and lower chip
http://www.tij.co.jp/jsc/docs/msp/ap...f/ANJ_1092.pdf
(japanese only)
Mr KAWAI(BB Japan) said
each chips different operation, If it connects, a bad influence .
Old 20th October 2005, 09:31 PM   #10
Yes, you are right. It is not ideal to simply parallel both chips.
However, I modified this DAC around 6 years ago on very low beget and wasn’t really considering spending long hours.
Simple paralleling did work okay with great results, by the way.
Together with silver wiring and some Panasonic capacitors replacement, the result was very good. Diodes were replaced with fast switching soft recovery types. This diode replacement worked very well and produced excellent results in analog valve section!
I think BOW Technologies implemented simple paralleling of PCM63 K with very good results as well. Around 6-7 years ago.
Extreme_Boky
Paia stack in a box Dusk Instruments and Amps 1 21st March 2009 04:35 PM
Stack of diy magazines Panelhead Swap Meet 3 24th March 2007 08:30 PM
How well does the Shiva stack up against SVS? mazeroth Subwoofers 4 11th May 2005 05:52 PM
Page generated in 0.10892 seconds (79.08% PHP - 20.92% MySQL) with 11 queries
