Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th October 2005, 05:56 PM   #1
Default Very low noise 7805?
Just wonder if anybody used the ST series of 7805, esp the precision 1A type L7805AC where the spec states 10uV from 10hz to 100khz, plus low output impendance of 0.017ohm. This is much better than even the lt317, lt1085.
It would be great if this is true as I can use it as I can use it as a simple drop in.
I will have to find it first however.
Old 9th October 2005, 06:31 PM   #2
Ops, forgot to paste the link to the datasheet.
http://www.st.com/stonline/products/...44/l7805ac.pdf
Old 9th October 2005, 06:39 PM   #3
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
eN is 10uV/Vo. That makes it 50uV @ 5V. The TS7805 is 40uV by comparison..
Mads K
Old 10th October 2005, 03:35 AM   #4
My mistake, thanks for pointing that out.
Same as other 7805 type.
Old 10th October 2005, 11:56 AM   #5
Assumed noise is flat, that would give 158 nV/SqrrtHz
Usually (!) some LF nose is still present beuound 10 Hz so I'd expect more LF noise and some 100 nV/SqrrtHz.
78/79 regs are extremely non linear in output impedance behaviour, avoid them, they act as mixers.
best
Guido Tent
www.Tentlabs.com
Old 10th October 2005, 12:22 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by Guido Tent
[snip]78/79 regs are extremely non linear in output impedance behaviour, avoid them, they act as mixers.
best
Guido,
If I want to avoid 317-type regs to limit the number of components, what 3-pin regs would you recommend for +/- 15V applications? If any ..
Jan Didden
Old 10th October 2005, 01:11 PM   #7
Originally posted by janneman
Guido,
Jan Didden
Hi Jan
Well, yes, if any....
In that range, the LT1086 would be nice, but that one hasn't got a counterpart which thus calls for 2 floating supplies tied together.
There is a number of tricks to make such 3 pin regs sound better. One of them is loading them such that their output stage delivers more current (hence becomes more linear). Still, they were never designed with audio in mind.
Currently, Tentlabs is designing a discrete regulator that subsitutes 78/79 style regs. Keep watching the webspace......
best
Guido Tent
www.Tentlabs.com
Old 10th October 2005, 01:50 PM   #8
janneman's Avatar
[snip]Currently, Tentlabs is designing a discrete regulator that subsitutes 78/79 style regs. Keep watching the webspace......
best
Thanks Guido, but take it easy, I've done that already ..
Jan Didden
Old 10th October 2005, 02:10 PM   #9
Jan Didden
Hi Jan
I know
best
Guido Tent
www.Tentlabs.com
Old 10th October 2005, 03:54 PM   #10
Zombie is offline Zombie  Sweden
Hi Guido and Jan!
Are your regulators a drop-in? Just pull the 7xxx out and the discrete in?
Cheers
Tom
When to use 317 and 7805? Sunsun22 Power Supplies 8 6th April 2009 07:47 PM
PSU with Multiple 7805 // Ciu Power Supplies 5 24th March 2007 04:46 PM
7805 trouble DragonMaster Power Supplies 4 23rd October 2005 03:38 PM
7805 to get 5V from car battery Morbid Parts 14 19th October 2004 08:39 AM
Why 7805 is better than LM1085? patwen Digital Source 198 2nd November 2003 12:53 PM
Page generated in 0.40017 seconds (25.92% PHP - 74.08% MySQL) with 10 queries
