Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th October 2005, 07:21 PM   #1
jzono1 is offline jzono1  Norway
Default Headphones too loud from cd player
My headphones play too loud with my philips 723 cd player. any quick fix for that? Even with volume turned all the way down, too load to my taste, soo load it is tireing to listen with them on it. 32 ohms heaphones is the problem.
Old 8th October 2005, 09:58 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Easiest thing is to buy another set of headphones that have a volume control in the cable.
Most DIY solutions would be rather large.
Old 8th October 2005, 11:07 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
even fitting pair of 1/4W 33 ohms resistors inline?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 9th October 2005, 09:45 AM   #4
No, i'm not replacing my beyerdynamic DT331 just because they play too loud. The resistor sounds like a good solution. Now, where do I get one locally?
Old 9th October 2005, 09:50 AM   #5
And, where do I put the resistors? I'm not afraid of opening the player 'n soldering some. not gcoing to get new headphones in the foreseeable future anyhow.
Old 9th October 2005, 12:58 PM   #6
Zen Mod's Avatar
open player and look where is located phone jack ;
in apropriate way just cut (desolder) hot wires from both channels and solder resistors across cuts.
33 ohms is just for start -if your ears decide that is still too loud,just increase values
Old 10th October 2005, 05:43 AM   #7
It will work, however you'll loose some top end resolution and dynamics in general, which you’ll notice immediately with your headphones! Avoid wire - wound resistors and try to get high power carbon resistors. Making a proper voltage divider at the OP output would work better.
I suggest to insert the voltage divider before the headphone OP (where you can use 1/4W resistor and you'll work with very low current - no inductance loss!), or to decrease the feedback around your headphone OP.
The latest is the easiest: you just solder in parallel to the existing feedback resistor another one of 3-4 times the value. You do not even need to remove anything – you can work from the top! Go gradually down in value.
Or use the trim pot and fine-adjust the feedback!
Extreme_Boky
Old 10th October 2005, 07:05 AM   #8
Electrons are yellow and more is better!
peranders's Avatar
Put a resistor in series, like 100-220 ohms or just use a pot connected a voltage divider. 500 ohms or 1 kohms is OK. I have this as a volume control when I'm testing my RIAA or headphone amps. 150 ohms headphones and 1 kohms gives me pretty good volume controlliing comfort.
100 ohms => 9.9 dB attentuation
220 ohms => 16.7 dB
/Per-Anders (my first name) or P-A as my friends call me
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 03:29 PM
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
T-amp, too loud, too soon Mr.Mekulic Class D 16 27th October 2006 04:40 PM
BIG LOUD 3 way? xstephanx Multi-Way 17 4th July 2006 09:43 PM
how loud do i need to go badger Multi-Way 6 8th January 2002 07:24 PM
Page generated in 0.08830 seconds (79.51% PHP - 20.49% MySQL) with 10 queries
