Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th March 2006, 02:37 PM   #101
Aghead is offline Aghead  Canada
I have to revise initial obsevations about copied CD's. After quite a few experiments with reading and writing speed variations, and using Nero's "jitter correction" (but haven't yet tried normalization or different media) it seems that no one conclusion is always valid.
In general the copy is less detailed than the original, proportional to the speed of both read and write. Not clear that "jitter correction" does anything.
In a very good recording this is a bad thing, it gets to sounding quite thin and the soundstage suffers - the point sources of speakers are much more obvious.
In harsh, digital noise recordings (like Lovett's Pontiac), it can sound better, as it seems to filter out more noise than music. So it can sound more musical and pleasant even though there is less detail, wierd.
Who knows if this is system specific, probably, but the differences are very noticeable. btw the cd is ROtel RCD bx955 with slight power supply cap mods.
Old 17th March 2006, 03:49 PM   #102
Gabevee's Avatar
You see Guido and others... Unless jitter is now defined as "anything within the read window other than the original bit", then jitter is not the issue.
If it was that definition, than any system that has that much information within the read window will sound bad. And contrary to Aghead's comments my experience has been that on my particular drive (TDK) the CDs always sounds better and more imaged.
Hence my ongoing dilemma.
We need to have a common ground though. What is "jitter" nowadays? Back in the day when I had to align hard drives, jitter was eliminated or minimized by some adjustments in the drive speed, the read circuit clock, the read window width (in milliseconds. Old systems. Slower) and so on. Those things went out of alignment on discrete circuits because of heat differences.
Nowadays with all that junk on a single chip, and automatic PLL type clock synchronizations etc., jitter is all but a historical footnote. In hard drives, anyway.
In any event, jitter was the back and forth movement within the read window of a bit, due to the hard drive platter's rotation inconsistencies. If jitter was too much, it would occasionally cause the bit to move outside the read window. Data errors ensued.
So you see my problem with the ubiquitous and to me gratuitous use of the term "jitter", it may have lost its true meaning, or taken on a new one. I read an article a few weeks back I think someone here posted a link to and I couldn't help but exclaim "BULL$H!T!". The person did not really have a full understanding of digital technology, as far as I could tell.
I mean, it was a real problem with linear data storage. But... CD data is not linearly stored. It is stored in an encoded format. Therefore, if there were some bytes with some bits of incorrect data, the BIOS coded program would decode the data stream and correct for any errors. This being after the data has been read into memory, thereby eliminating any "jitter" induced errors to begin with. Oh, any jitter induced errors would most likely be corrected for with CRC checking even before being decoded and rearranged for DAC processing.
I mean, if jitter was bad enough on either the disc or the drive, the freakin thing would not read very well, and would really go nuts if both were bad. Guess what? Time for a new CD player!
Or... maybe things have changed that much in the 23 years I have been in the business?
Naaaaaahhhhhhh.
Gabe
Gabe CGV Electronics
Home of the CGV-300B amplifier on a budget
Old 19th March 2006, 08:01 AM   #103
I think nowadays the issue may be present only in case of
(a) really unstable internal cdp clock (throw the cheap junk away)
(b) external dac over spdif link with unstable transmitter clock and receiver that follows too closely this clock (get a decent external dac, the all-on-one-chip that has spdif on the left and analog out on the right costs about 5 bucks, so it's not rocket science to build one)
The rest consists of audiophile horror tales in which any perceived sound problem from bad recording to poor speakers / placement is blindly blamed on jitter.
Old 19th March 2006, 08:59 AM   #104
405man is offline 405man  Scotland
I have a CD player that uses a Philips CDM4/!9 and when playing original CDs there is a chirping noise from the mechanism which is disc speed related when I play copied CDs the noise is considerably reduced or not present at all. This suggests that there is a difference in the amount of work the servo does with different discs. I have not yet had a chance to investigate further
Stuart
Old 19th March 2006, 10:46 AM   #105
Naaaaaahhhhhhh.
Gabe
Gabe
All proper CD plaback systems retrieve data from the disc without errors, that is NOT the issue (it has been shown by measurements many times). Discs however contain jitter, and that amount differs disc by disc (Not only among various CDr discs but also among commercially made discs !).
That jitter ripples through and affects playback quality. Crosstalk of jitter takes place through power supplies and layout errors.
Finally the playback is affected once the conversion clock is affected as well (Note, I mean the clock quality ON-CHIP). At that moment a time error is converted in an amplitude error. That is why we hear differences.
I agree if you don't agree but would expect another explanation rather than stating "it is not the jitter".
best
Guido Tent
www.Tentlabs.com
Old 20th March 2006, 05:02 AM   #106
I just wanted to put my two cents in, so here goes. A CD has two sources of jitter, as most of you know. There is inherent jitter in creating the original analog-digital transfer. Let's call that JO (original jitter). Next, when the transfer is burned to a CD, there is some additional jitter, due to any imprecision in the pit spacing/depth, etc. Let's call that JT (transfer jitter). So, when you play that disc on a standard CD (without buffering or anything fancy), the playback is subject to those two sources of jitter. Now, suppose instead that you rip the CD to your computer. Well, you have suddenly gotten rid of JT (not JO, of course). So, when you burn this copy to a new disc, you will create a new source of jitter. Let's call it JB (burn jitter). Clearly, if JB<JT, then this new disc may sound better (if you believe jitter is audible) than the orginal CD on the same cd player (or through the same DAC). If JB>JT, the CD could sound worse. It simply depends on whether the burner imparts less jitter than the original CD transfer had.
Old 20th March 2006, 09:15 AM   #107
The JO does not expose as jitter but as errors present in the data due to jitter present in the conversion process. You will never get rid of that, never, so make sure your AD has lowest jitter possible (among other things).
Newly written discs may have lower pit jitter indeed, depends on the disc and writer. It is good to know that original discs differ in jitter too as the mould ages.....
In addition, other parameters affect read-out jitter like a-centricity and reflections from the upper surface.
best
Guido Tent
www.Tentlabs.com
Old 20th March 2006, 09:22 AM   #108
Nordic is offline Nordic  South Africa
Nordic's Avatar
Just to add oil to the fire...
Straight from the EAC homepage
Known Bugs:
Some older CD-ROMs cause extreme jitter errors to occur on some CD-ROM drives causing the extraction to slow down to an unacceptable rate (e.g. Mitsumi FX240)
Old 20th March 2006, 06:30 PM   #109
Data isn't just poured from pits and lands to the dac. You must decode it (from efm to octets) and run it through error detection and correction (rs codes). Not sure you can do all this with absolutely no buffering. So much about this kind of jitter.
When you rip using DAE the jitter it another kind of jitter. Audio sectors do not include address information (header) so you cannot be sure you got the right sector when you start a read command. You mai get data from the previous sector for example. This used to happen on old cdrom units but it is no longer the case with modern ones (don't ask me how they do it).
This does not apper at audio playback because you just play continuosly, not do read-sector-save-to-hdd loop.
So, here we are stuck mostly with recording jitter from studio ADC conversion. This one remains constant no matter what you do. Hopefully they have better gear than we do.
Old 23rd March 2006, 07:29 PM   #110
I am not sure that this jitter discussion really helps correlate what I'm hearing.
Now that I have done a few tests, the results are getting predictable.
As in, give me two recordings - original and copy, and I will tell you which is which. Same with 1st copy and second copy (of the 1st copy)
Also, if you have two otherwise identical hard drive images, I can tell apart two burnings made at different write speeds and identify the higher and lower.
This is true of both CD burners I've tried, with totally different burners, hardware, software, and locations.
That kind of empiric reproducibility must have a testable basis - like compare the digital signals being read on the player to maybe discover whether this discussion on jitter really means anything- is that possible?
PC sound card sound chips kaluchka Chip Amps 6 20th June 2011 03:48 PM
SE sound vs Ultra Linear sound flysig Tubes / Valves 1 9th May 2009 10:21 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Roland VS-1 Sound Module - No Sound! jazzbee Instruments and Amps 1 3rd March 2006 08:39 PM
Enlighten me please - why does the quality of copied audio CD's deteriorate so bad? mr_push_pull Everything Else 27 21st February 2005 03:32 PM
Page generated in 0.15951 seconds (85.08% PHP - 14.92% MySQL) with 11 queries
