Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd October 2005, 06:09 AM   #1
Default Get Rid of the Small SMD Capacitors on CDROM for Better Sound
I was told that small SMD capacitors (small rectangular capacitors)on PCB of CDROM can be removed for better sound. Have anyone try this and I would like to learn the thoughts. Can anyone tell me where I can find schematics of CDROM so that I can check which capacitors I can remove?
Old 3rd October 2005, 07:47 AM   #2
Take out those nasty control ICs too: they just add digital noise to the DAC.
Old 3rd October 2005, 07:49 AM   #3
you probably mean ceramic caps placed on audio traces.
Old 3rd October 2005, 10:16 AM   #4
Well,
the SMD capacitors provide the best theoretical noise attenuation / decoupling. No legs, and if the ground plane area is maximized and with no noise, they work wonders. The problem is finding”nice” sounding ones...
Someone here on forums reported Murata 22uF SMD ceramic as excellent choice....
Extreme_Boky
Old 3rd October 2005, 11:14 AM   #5
Thanks Extreme_Boky, frdchang and DSP_Geek for quick replies.
However, I thought the ICs are for servo control and laser control. Would appreciate if DSP_Geek can provide further details.
Extreme_Boky, do you mean that I should keep the ceramic caps?? Or I should replace them with good ones as you suggested (Murata 22uF SMD ceramic).
Old 3rd October 2005, 02:00 PM   #6
Banned
Why do you think that a 22 uF ceramic cap could possibly be good?
Jocko
Old 3rd October 2005, 02:10 PM   #7
In 22uF the only reasonable choice is electrolytic, yes? I could see ceramic being used for values of 0.1 uF and under but 22...? That would have to be Z5U and Z5U sucks.
Old 3rd October 2005, 06:32 PM   #8
You do realize I was *joking*, right?
Anyway, the caps are on the circuit board for a reason: they keep the supply voltage from bouncing around. Removing them could cause the CD-ROM to work intermittently or not at all.
Old 3rd October 2005, 08:35 PM   #9
Jocko,
I accept that a 22uF cap sucks big time quality wise.. But where the quantity maybe counts more than the quality.. [digital]
It would be good to know, if You have any seriuos objections. Because also me makes part of that world who has been lured in..
And had spent money on such things..
Though I got only the 10uF ones - I'm a modest guy. Also some 1uF, about this later. They are damned small, for testing them I had to make a better jig.
Ecco l'impedance of a common 100nF/50V x7r:
Old 3rd October 2005, 08:37 PM   #10
And the parallel combination of a 10uF /10V Z5u // and the same 100nF:
Need small coupling capacitors pandaemonium9 Solid State 4 13th November 2006 06:51 PM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 07:16 PM
Different CDROM,different sound?? Leolabs Digital Source 1 20th August 2006 01:54 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.11017 seconds (79.74% PHP - 20.26% MySQL) with 11 queries
