Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st October 2005, 10:15 PM   #1
Sandor is offline Sandor  Italy
Default Source for TDA1541 double crown
Can anyone suggest a source for a TDA1541A S2 (double crown) ?
Best regards.
Paul
Old 2nd October 2005, 02:01 AM   #2
X.G. is offline X.G.  China
X.G.'s Avatar
a chinese member ever selled the TDA1541 double crown on here before.
....but basing on my experience,I think that you maybe get 3 or 4 even 5 crowns if you improve the layout of TDA1541 DAC PCB
Old 2nd October 2005, 05:15 PM   #3
tubee is offline tubee  Netherlands
tubee's Avatar
Yes indeed, the 1541 is very sensitive in this.
Daisy Bell
Old 2nd October 2005, 08:50 PM   #4
Thanks for your suggestions. I'll submit to your attention the pcb layout i am going to draw.
I have read that the decoupling capacitors need to be as close as possible to pins 7-13 and 18-24, and with the shortest path to the analog ground (pin 5). Placing some SMD capacitors on the bottom side of the pcb, directly soldered on the TDA1541 pins may satisfy these requirements; is this a good idea? I have some small polypropylene SMD 100nF 15V caps. Are they suitable to that job?
Best regards.
Paul
Old 3rd October 2005, 04:53 AM   #5
X.G.'s Avatar
Best regards.
Paul
I didn't try.... maybe a very good idea.but you should pay enough attention for the loop of digital signal return current and loop of the power supply current on here.
Old 4th October 2005, 05:25 AM   #6
tubee's Avatar
Ground the caps at one point in the middle just underneath 1541 if possible.
Daisy Bell
Old 5th October 2005, 09:45 PM   #7
Thank you for help.
Best regards.
Paul
Philips CD 650 NonOS TDA1541 Double Crown Fabian Swap Meet 0 16th December 2008 05:18 PM
FS: 14 x TDA1541 & 1 x TDA1541A S1 crown Bernhard Swap Meet 1 10th August 2006 05:20 PM
Where to buy TDA1541 Double Crown? MGH Digital Source 3 4th May 2006 04:36 PM
tda1541 s1 crown wanted weegs Digital Source 1 9th March 2006 08:01 AM
Getting the best out of a Double Crown TDA1541 pauldyworth Digital Source 0 17th August 2005 10:08 PM
Page generated in 0.07825 seconds (76.70% PHP - 23.30% MySQL) with 10 queries
